Old 05-16-2008, 02:13 PM   #151
Car: STI UGM LTD
Send a message via AIM to johnsm Send a message via MSN to johnsm
Default Re: 400++WHP 06 STI Project...Blouch DOM 3.0R + Devils Own Meth Kit and a TMIC.. LOL
What dyno you will be using?
johnsm is offline   Reply With Quote
Old 05-16-2008, 03:27 PM   #152
Car: 04 WRX 'blk prl' STi
Fav Mod: Injen CAI w/ used filter :D
Originally Posted by johnsm View Post
yes. Bad combination of headers and uppipe made a big exhaust restriction.
I order grimmspeed uppipe and will be welding 44mm gate to it, and will order there PnP manifold from them as well.
I'm selling greddy headers and ultimate racing uppipe (i guess they incompatible with each other)
lol
question for you: if the hole in the uppipe is larger than the actual "entrance" on the turbo where it bolts onto the uppipe, is this bad? (im guessing yes)
sti_schumacher is offline   Reply With Quote
Old 05-16-2008, 03:43 PM   #153
Car: 06 STI / STG 4
Fav Mod: DOM 3.0R + METH!!!!
Dynojet over @ Precision Tuning.. Getting tuned by John he is a awesome tuner.. You have a 07 with a DOM 3 check out his tune on his own car which is a 07 aswell with a DOM 3 over at Power Bragging he is a real cool guy and great tuner. You should pick his brain on a few things, he is always willing to help guys out especially with 07's. His name is SubyTuner on here..
Old 05-16-2008, 03:45 PM   #154
unfortunately i have 04
thanks
Old 05-16-2008, 04:00 PM   #155
Car: STI UGM LTD
Port it!
Old 05-16-2008, 04:02 PM   #156
Car: 06 STI / STG 4
thanks
I was talking to the other guy... Johnsm.. But he can tune an 04 no prob
Old 05-16-2008, 04:20 PM   #157
Port it!
what exactly does that mean???
Old 05-17-2008, 12:10 PM   #158
Car: STI UGM LTD
Port and polish turbo!
Los any news on tune?
Old 05-17-2008, 03:35 PM   #159
Car: 06 STI / STG 4
Update.. Well had some problems the shop called me on Friday and said they couldnt fit the APS TMIC back on with the Dom 3. I said I know you can run it with a DOM 3 long story short they called me today and ended up using a longer elbow pipe and moving th coolant line a bit to make everyhting fit ok..... Ok no prob.. Then they called me back and said the Meth kit was on the pump was primed and when they turn the car over and the controller got power to it, it started to smoke the controller that is.. They said they double checked all connections to see if something was wrong it was all good but the controller was just smoking as soon as power got to it... I am a bit pissed wanted my car back, but there is nothing I can do. I will call Devils Own on Monday and tell them what happened and see what they say. I guess I wont have my car tuned till next week
Old 05-17-2008, 05:29 PM   #160
Car: ugm 2007 sti
Fav Mod: xxchris tune
thats unfortunate.... hope all works out for you. As far as the dom 3 not fitting will that be the same for the blouch 20g and aps top mount... both of which I just ordered... I would assume the the 20g is smaller. Probably will regret the purchase after seeing yours.
MidLfCrisis is offline   Reply With Quote
Old 05-17-2008, 06:55 PM   #161
Car: 06 STi
^^The Dom3 fit w/STilos's APStmic. It just took some patience for precision to get it to fit, along with a longer inlet coupler.
Carlos, sorry to hear about the controller issue.
Old 05-17-2008, 10:50 PM   #162
Car: 06 STI / STG 4
Yeah your fine... The 20G is no prob at all with the APS TMIC... The DOM 3 is WAY bigger then the 20G and like neverendimods said it was just a matter of making it fit just moving some things around and a longer elbow coupler.. Not a issue any longer. It will work out, the installs are not anyhting major, I think they made it bigger then it was you know what I mean.. Why would you regret the purchase after mine? You have to rember my setup is way diff then yours The DOM 3 is alot bigger 52lb Turbo compared to the 20G 44lb also I am running Meth. The APS TMIC is gonna be more then enough you would probably be fine with the stock TMIC so dont worry.... But dude get some Meth on there and you will make 400WHP with that 20G.. Oh by the way you got the TD06 20G 8CM right? Make sure you get the standard inlet 2.4 aswell.
Old 05-17-2008, 10:59 PM   #163
Car: 06 STI / STG 4
Hey dude... Yeah the controller issue Not a problem my boy Chance the owner of Devils Own called back and had a new controller sent next day to the shop no questions asked.. That is pretty good CS especially after he gave me some much free stuff aswell.. Funny how the Controller just started SMOKING but they claim all wiring was spot on, you know all 4 wires of this insanly complicated meth kit.. Controllers just dont fry up on themselves you feel me.. I will keep you posted it should get tuned on Tuesday..
I think since now they have some time on there hands till they get the controller. I want them to run the dual nozzle setup I was thinking if the 10GPH is what I need then maybe a dual setup running a 7GPH and a 3GPH which comes out to a 10 would be cool.. My thinking is if the charge comes in and gets sprayed up top and that cools it, and then it gets sprayed down low again it will give it a second cooling effect?? I am not sure seems like it cant hurt to try you know..
Hey Eric you want these Goldies.. I want some Enkei's...
Old 05-18-2008, 08:49 AM   #164
Fav Mod: CP35r 440whp
FWIW, I ran an "M15" nozzle on my 30r kit (and currently)...i dunno if that's 15gph or whatever, but it's a big nozzle. I would suggest that size
Old 05-18-2008, 05:07 PM   #165
Car: 06 STI / STG 4
Well it really depends on the pressure to figure out GPH or gallons per hour.. And its about the ML/MIN that you really want to go by. A M15 nozzle @ lets say 40psi of pressure would be 9.5 GPH. For example if you went with aquamist kit there big nozzle is a 1.0 which flows 325ml/min thats why they always do a dual nozzle setup. With our kits and pretty much all US based meth kits the nozzle are rated diff and flow alot more. Like SNOW's bigest nozzle flows 625ml/min and they say that is good for 500+whp, I am probably gonna run the 10 which flows 630ml/min per devils own charts, or I may do a 7 and a 3 for the same flow but with a dual setup.. Not sure.. The M15 is pretty big I dont think I need that much Meth.. I know Steve @ SMC suggests the M15 I dont know cause that is probably about 1000ml/min which is alot. What kind of power are you putting down..
