Go Back   IWSTI.com: Subaru STI Forums > STi Owners' Lounge > Members' Journals
Old 12-02-2007, 12:36 AM   #1
Car: 07 STI
Fav Mod: Zzyzx Coilovers
Default JD's 07 STI: X-Brace causing oversteer, should I switch sways?
---------------Updates with Pictures---------------
-Brake Overhaul - New Ferodo Pads, Stoptech SS Brake Lines, ATE Fluid, Cusco Brake Stopper (Post 83)
-Zzyzx Coilovers Installed & Car Aligned (Post 62)
-Zzyzx EM Sport Coilovers Double Adjustable F&R (Swift Springs 10k/7k) (Post 42)
-GTspec 3-Piece Subframe (Post 29)
-Whiteline 24mm Adjustable Front & Rear Swaybars (Post 28)
-GTspec Fender Reinforcement Braces (Post 16)
---------------MOD LIST---------------
Key:
Black: current mods
Blue: future mods
Engine:
-Stock VF43 Turbo
-APS R1 3” Turbo Back Exhaust
-APS High-Flow Cat
-Kartboy Exhaust Hangers
-Walbro 255lph fuel Pump
-Kartboy Aluminum Pitch Stop
-AMSOIL
-Element Tuning Catch Can
ECU Tuning & Performance Electronics:
-Cobb Access Port Ver. 2.0 Protuned by Harman Motive
-Braille B14115 Lightweight Battery 11lbs 8oz
-JDM Auto I/C Switch wired to:
--Boost Pressure Sensor (sprays at 10 PSI because I'm too lazy to push a button)
-Turbo XS Knock Light
-Bosch Knock Sensor
Power:
285WHP/318WTQ - 91 octane @ 19 PSI
300WHP/365WTQ - 95 octane @ 22 PSI
Driveline:
-Cusco Motor & Tranny Mounts
-Kartboy Short Shifter
-Kartboy Front & Rear Shifter Stay Bushings
-TIC Shift Linkage Bushings
-TIC 6MT Shift Linkage Bushings
-TIC Tranny Crossmember Bushings
-TIC Unabomber’s Sexy Rearend:
--TiC Rear Differential Mount Bushings (Race)
--Kartboy Rear Subframe Outrigger Bushings (Race)
--Whiteline Rear Subframe Lock Bolts
-AVO Gearbox Mount Bushings
-ACPT Carbon Fiber Driveshaft
-Motul Gear300 75W90 Transmission Fluid
-Motul 90PA LSD Fluid
Suspension, Handling & Stiffening:
-Car Lab X-Brace
-Noltec Camber/Castor Plates (Front)
-Cusco Camber Plates (Rear)
-Whiteline Heavy Duty Swaybar Mount
-Kartboy Endlinks (Front & Rear)
-Cusco Rear Trailing Arms
Steering:
-Whiteline Steering Rack Bushings
-Q-Rack Quick Steering Rack 11:5:1 Ratio
Braking:
-Cusco Brake Cylinder Stopper
-Stoptech Stainless Steel Brake Lines
-ATE Super Blue Brake Fluid
-Ferodo DS2500 F&R Brake Pads
Wheels & Tires:
-I ran out of $$$
Interior:
-Defi-Link Control Unit II
-Defi BF Amber 60mm Gauges:
--Boost
--EGT
--Oil Temp
--Oil Pressure
--Water Temp
-Clock Pod
-A-Pillar Pod
-Wideband O2 Sensor (suggestions?)
Exterior:
-Window Tint 10% Rear/35% Front
-V-Limited Lip
-Painted Black Head Lights (painted by me)
-Lightwerkz Chrome/Amber Blinker Bulbs (for headlights & tail lights)
---------------Pictures---------------
Defi in A/C vent
Braille Lightweight Battery 11lbs 8oz
I purchased my 07 STI in May 2007 from South Coast Subaru. It had 4 miles on the OD. I had always been given old hand-me-down cars so this is the first new car I have owned. I've been upgrading things since day one. Fortunately my very first mod was the Access Port; I flashed to Cobb's stage 1 map at about 1,000 miles. This took care of the hesitation, but then I got bored. Next, I purchased the exhaust, a few other bits and went into Harman Motive for a tune. By the time I installed the TBE & got tuned the car had about 6,000 miles. Since the tune I have gotten bored several times. Not bored with the car, I'm talking about bored on the weekends. And when I get bored I buy more parts and install them. It works out pretty good.
Old 12-02-2007, 11:28 AM   #2
Fav Mod: Ecutek'd GT30R
Send a message via MSN to WRXTek
Default Re: Volk/Gram Lights 57F's ordered, more to come!
really nice and clean. nice garage too
WRXTek is offline   Reply With Quote
Old 12-02-2007, 11:34 AM   #3
Car: 06 STi Spec C
Fav Mod: The STi experience
Nice job man! Car looks great, make sure you get pics of the 57F's installed!
06SpecC is offline   Reply With Quote
Old 12-02-2007, 12:30 PM   #4
Welcome to The Board
Car: 06 WRB STI
Fav Mod: Advan RS
Send a message via ICQ to Ikon Send a message via AIM to Ikon Send a message via Yahoo to Ikon
car looks good
Old 12-02-2007, 12:40 PM   #5
Fav Mod: BOV and MBC
Nice car and Beautiful house!
Old 12-02-2007, 12:56 PM   #6
STI PILOT
Fav Mod: MY GARAGE PERIOD
that battery idea is hawt!!!! put up pics when you get the wheels on
Novtec1 is offline   Reply With Quote
Old 12-02-2007, 04:05 PM   #7
Car: 07 STI
Thanks!
It's my Pop's house. Unfortunately the bikes are his too, but the car's all mine. We just finished building the house this year. It wasn't more than a giant mountain of dirt & sticks a couple years ago. My brother and I built the garage doors & hung them, which took us weeks.
I should have the wheels in a month or so, I'll be sure to post some pics. I need to figure out what size tire to get, as noted in red above. In about a week I should have the cusco mounts.
Novtec, thanks. I figured since the battery is so tiny I may as well get it as low as possible. It's about a $4.00 mod, which consists of a couple pieces of 1/4" all-thread, some washers & nuts and a metal saw and pliers to bend the all-thread. I suppose you could just cut and re-bend the stock hooks but I l chose to keep them & the stock battery incase my braille takes a crap.
Old 12-02-2007, 07:38 PM   #8
Send a message via AIM to nice-rice
Looks good man, nice journal. And nice choice of rims, they should look pretty badass on the car.
nice-rice is offline   Reply With Quote
Old 12-03-2007, 05:16 AM   #9
Car: 96 Outback Wagon
Fav Mod: Autobot Decal
Trader Rating: (21)
Send a message via AIM to Einobaka
Nice d00d! Return those Grams and buy mine x)
Einobaka is offline   Reply With Quote
Old 12-03-2007, 01:26 PM   #10
Wheel33tist Whore
Ok, where to begin.
first with your suspension uncertainty I would run a 235/40/18 since it will work with almost any ride height and almost any suspension you choose.
Lugs 12x1.25 is the proper thread pitch.
Centercaps you'll need should be the WR Center Cap (it says "rays" on it).
you don't need the Perrin Adjustable rear lateral links.
Coilovers really depend on your desired application and your ultimate budget.
are you for sure jumping to coilovers? if so you may be able to run something more along the lines of a 255/35/18 RE01R from the start.
but if you think you wont buy coilovers for a little while then you might as well get some cheaper 235/40/18s that you know will work with any suspension you use in the future.
and once you get to your final suspension setup you can go as wide as possible.
my $.02
t3h_
T3h_Clap is online now   Reply With Quote
Old 12-03-2007, 03:05 PM   #11
Fav Mod: jailbreak
good numbers on harman's dyno!... for coilovers, you got some good choices there. i say get what is in stock and their corresponding camber plates. that way you can get them on before the rims get mounted i have tein flexes,but super mad tyte suspension gods seem to hate them . i on the other hand love them. second car i've had teins on. won't be the last. been on teins since 2001
Old 12-03-2007, 03:16 PM   #12
Wheel33tist Whore
It's hard to know how green the grass on the other side is if you never look at it.
Personally I'm liking the new TiC ASTs and the upcoming zzyzx EM Coilovers
Old 12-03-2007, 07:28 PM   #13
Car: 07 STI
Thanks Clap. I'm not really in a rush here so I think the best thing to do is get the coilovers figured out first, then buy the tires. I added KW Variant 3's to the list. Hopefully TIC gets theirs to market soon. Something tells me to wait for them.
Old 12-03-2007, 07:39 PM   #14
Fav Mod: jailbreak
i've rode on other setups. some ride good, some don't. noticed i said he had some good choices there. i know alot of people like the rce's and the cusco's are great. i've also rode on jic's,apexi's,hks's,zeals, and a ohlin setup. all have there good/bad sides. mine tend to be too stiff for some people
Old 12-07-2007, 07:05 PM   #15
Car: 07 STI
Default Re: Santa Clause came to town!
I picked up some goodies today (PICS will be up tomorrow):
Cusco Motor & Tranny mounts
Whiteline 24mm Adjustable Rear Swaybar
Whiteline 27mm Adjustable Front Swaybar
Whiteline Anti-Lift Kit (Race Version)
GTSPEC Fender Reinforcement Braces
STI JDM Lug Nuts, Black & GOLD!
After seeing GTSPEC's fender braces I'm thinking about ordering this also:
GTSPEC Subframe Reinforcement Brace (3 piece set)
I've narrowed the coilovers down to 2. I'm stuck between the KW Variant 3's and the zzyzx EM Sports.
