Old 02-28-2008, 07:27 AM   #46
Car: 05 Aspen White/Gold
Fav Mod: Öhlins FP
Default Re: JD's 07 STI: 02/26/08 Zzyzx EM Sport Coilovers arrived (Pics found here)
Wow! So nice...
alphaSTI is offline   Reply With Quote
Old 02-28-2008, 01:21 PM   #47
Car: 07 STI
Fav Mod: Zzyzx Coilovers
I'm just bummed that my wheels haven't arrived yet. I don't think I can wait for much longer. I may just go with something different.
Old 02-28-2008, 05:28 PM   #48
Fav Mod: 255's ftmfw
Send a message via AIM to sticop
that subframe is a work of art.
hope noone jacks your lugs!!
sticop is offline   Reply With Quote
Old 02-28-2008, 06:44 PM   #49
Car: 07 STI
yeah, I may get something different.
Old 02-28-2008, 07:21 PM   #50
Car: 06 WRB STi
Fav Mod: All stock
Have you put your coils on the scale?
lovesmysuby is offline   Reply With Quote
Old 02-28-2008, 07:33 PM   #51
Car: 07 STI
damn, I don't own a scale. I'll go by the post office this weekend & use theirs. I will let you know.
Old 03-04-2008, 06:18 PM   #52
Car: UGM 07 STi
Great Journal, looking to do alot of the same things your doing to your STi. Great pix's & Info of all your mods... What made you choose those coils, over others? I was looking at the Tein Mono Flex or Flex w/ EDFC, so I can make it soft when driving day to day to work. Have you AutoX yet with these mods? I hope to Autox this summer. What web site do you order from mostly? Its hard to find a great price & vender that you trust. Again great work & a nice ride Bro!!!!
HK40EXP is offline   Reply With Quote
Old 03-06-2008, 06:13 PM   #53
Car: 07 STI
Thanks!
I'm not into autocross. I'm gearing up to begin tracking it on road courses. But since it's my DD I went conservative on the power end to maintain reliability and focused more on handling.
I chose the coils for a number of reasons. They fit my needs. If you do your research and identify what you value in a setup then the decision should be easy.
here's some info
EM Sport Coilovers | Zzyzx Motorsports
Zzyzx Motorsports: EM Sport Coilovers
JD
Old 03-07-2008, 06:24 PM   #54
Fav Mod: Gram Light 57F's
Send a message via AIM to jordanretro1223
You get the coils installed yet?
jordanretro1223 is offline   Reply With Quote
Old 03-07-2008, 07:44 PM   #55
Car: 07 STI
Next weekend. The alignment shop I'm going to is backed up 2 weeks so I had to plan the install around that.
Old 03-08-2008, 01:31 PM   #56
Fav Mod: TiC AST's - 7/6K
Nice coilovers! I can't wait to hear your review on how they ride. What ride height are you going for?
Old 03-08-2008, 07:29 PM   #57
Car: 07 STI
I've have had plenty of time to sit there and tinker with them, which is fun. But they need to go on. Install next weekend, then alignment, then it's time to review.
Steve suggested I start with 14.25" front, 13.75" rear. I'm open to more suggestions though. Not looking to slam the car.
Old 03-08-2008, 08:01 PM   #58
Car: 07 STI
Default Re: JD's 07 STI: 03/08/08 Installed the Cusco Mounts today
Finally got the Cusco motor & tranny mounts in today. Holy NVH Batman. The result is exactly what I was hoping for. I haven't had time yet to really get on it but after a quick spin around the block it feels amazing. Less drive line lash, more rumble, and I feel much more connected now.
The install was a PITA, but not difficult. I actually though it was quite easy. But I've taken the underside of the car apart several times.
I started by looking at this how-to: Cusco Engine & Tranny mount install guide. - i-Club
But soon realized that everything in that install is @ss backwards. On the motor mounts, he doubled up the washers on one side. In the two pictures where he shows how it didn't fit the first time, then once he moved the washers it fit... well, look at the pictures closely. it's pretty obvious why it didn't work the first time; he had the damn mount positioned the wrong way on the plate. Putting two washers on one side and NONE on the other makes no sense at all. I had absolutely no problem with the alignment by leaving the mounts as they came assembled from Cusco, with one washer on each side.
That how-to also does not show where to place the two large black washers, which are very important, that come with the tranny mount. They are supposed to go in-between the mount & the cross-member. There are also no torque specs for the through bolts on the Cusco mounts in that how-to; they should be torqued 30-35 ft/lbs. After about ten minutes I threw that guide out & just referred to the subaru service manual.
Old 03-09-2008, 06:52 AM   #59
I just set my new TiCs to 14.0 front, 13.5 rear. That is the magic number for the best combo of lowering and best handling. Raising it up a tiny bit like Steve suggested might make it a little more driver friendly. On one really steep driveway I think I scraped my nose a little bit and the extra quarter inch probably would have helped.
Old 03-09-2008, 10:14 AM   #60
Car: 07 STI
I think I'm going to set it to try 14 front 13.5 rear & see how I like it. If it's scraping too much I'll go up a bit. It's the v-limited lip that scrapes. It's already scraped so I'm not worried about a few more scrapes.
How long does it take for the springs to settle?
