Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > Mauro Motorsports
Old 05-23-2004, 08:01 PM   #1
Car: 2004 STi
Fav Mod: FP Green
Send a message via AIM to MauroMotorsports
As the subject states. We have ONE HKS GT2540R turbo kit available. They've discontinued this model, so we have it on Special for a great price. Act now because this won't be around long! Will bolt right up to any 2002-2004 WRX or STi and uses the stock IC or any aftermarket FMIC.
Contents include:
· HKS GT2540R ball-bearing turbo (internal wastegate)
· 150mm HKS Super Mega Flow air filter with airflow meter adapter and piping
· Up-pipe (Off-Road use only)
· Downpipe with split housing turbine extension (Off-Road use only)
· Oil lines, water lines, hoses, miscellaneous brackets and fittings
List price was $3250
Get the whole kit for $2299. <----click to order or for more info.
This setup is totally different then stock. It puts the turbo at an angle totally bypassing the typical through the intake manifold setup. The HKS downpipe supplied will hook up to ANY aftermarket USDM catback exhaust.
HKS "claims" you can run this setup at 14.5psi on the stock injectors and ecu, but of course a good set of injectors, fuel pump, and managment will certainly help. People have run this setup into the low 12's on a WRX. Imagine what it can do for an STi!
The best part is you don't even need to have a front mount! This turbo will bolt right up to your stock TMIC or an aftermarket TMIC.
Cheers!
MauroMotorsports is offline   Reply With Quote
HTML code is On
