Old 09-27-2007, 07:55 PM   #1
Car: 05 aspen white
Fav Mod: element gt52
IWSTI Addict since: Apr 2007
Default NEED Help ASAP
Ok so I'm trying to install my gauges (mad dad) off the center clock.
Here's what I need
  • RED – Battery + (or any +12v constant source)
  • BLACK – Ground
  • ORANGE – Ignition or other +12v line that does not loose power when turning your key from Accessory to Start, but does shut when the car is powered off.
  • YELLOW – Accessory
  • BROWN – Illumination (any +12v source that turns on when the headlights are turned on and turns off when the headlights are off (headlight fuse for instance). When your headlights are turned on this will dim the contrast of the backlighting(fixed amount non adjustable).
I was told I could get all this off of my clock, but the best I've been able to get the gauges to do is light up when i go from off to acc.. they make a buzz and then nothing!!! i am suppossed to be tuning tomarrow, but not if I can't get this to work.. Please help
Anyone have a wiring diagram for the clock???
wakeboarder81 is offline   Reply With Quote
Old 09-27-2007, 08:07 PM   #2
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
Default Re: NEED Help ASAP
It is on the clock. If you look at the clock pod it will be posted on it
Old 09-27-2007, 08:15 PM   #3
Car: 05 aspen white
Ok got it, and attached my red power to my constant bat from the clock. attached ground to ground, brown to Light on the clock, and acc to my ignition line and now nothing at all
Old 09-27-2007, 08:24 PM   #4
Car: 05 aspen white
anyone else with maddad gauges and a center pod care to comment?
Old 09-28-2007, 04:58 AM   #5
Fav Mod: a garage
IWSTI Addict since: Sep 2005
Pm meridock. He's rearranged his enough times, he should know how they are wired pretty well.
sti robot is online now   Reply With Quote
