Old 10-04-2007, 08:13 PM   #61
Car: 07 Subaru WRX STi
Fav Mod: Stage 2 :D
IWSTI Addict since: Mar 2007
Default Re: Annoying rattle source found!
My exhaust is pretty dang loud, and I can still hear mine! Thanks for finding that Fast08... im going to do that first thing in the morning and ill let you know what i find.
-HC
holycow is offline   Reply With Quote
Old 10-04-2007, 08:28 PM   #62
Car: White 07 WRX STI
Fav Mod: Driver weight reduction
IWSTI Addict since: Jul 2007
Sure thing man, remember it's the strip along the roof, NOT the 2 side rubber strips next to the C pillars from outside. Good luck.
Originally Posted by holycow View Post
My exhaust is pretty dang out, and I can still hear mine! Thanks for finding that Fast08... im going to do that first thing in the morning and ill let you know what i find.
-HC
fast08 is offline   Reply With Quote
Old 10-04-2007, 10:16 PM   #63
Fav Mod: Stage 2 :D
hey Fast.. ok, I see the little rubber strip that goes left to right at the very top of the glass. Now, which side do you lift and spray under? The top side, or the bottom side of the strip?
Old 10-04-2007, 11:24 PM   #64
It's the side that touches the body work. Create a gap between the strip and the roof using the end of a zip tie or a thin plastic card and spray along the edge while moving the zip tie. Hope that's clear, or else I can take a picture.
Old 10-05-2007, 06:13 AM   #65
Fav Mod: Fixing Subie Rattles :)
IWSTI Addict since: Jan 2006
Send a message via AIM to SiCkSTi04
i lowered my lower trunk latch last night, then this morning i went to work OMG the noise is gone w00t! i had it down to when it should make the rattle noise but it's now silence hehe.
i'm going to do the axle nut fix too next week.
thanks again!
SiCkSTi04 is offline   Reply With Quote
Old 10-05-2007, 09:56 AM   #66
Car: 2007 OBP/Gold Wheels
Fav Mod: Prodrive Mudflaps
IWSTI Addict since: Apr 2004
Fast08- Is the rattling still gone from your fix?
Old 10-05-2007, 10:24 AM   #67
3+ days and still rattling free. Fix doesn't work for you?
Old 10-10-2007, 03:06 PM   #68
Well, I am pretty confident the rear windshield rattle in my car has been fixed. I sprayed WD-40 along the top edge of the outside of the rear windshield and haven't heard anything since. I just got back from a long drive up to Mohegan Sun, CT and didn't have any rattling at all. I highly recommend trying this if you have that stinkin' rattlin'. Great job Fast08 on finding this fix!
Old 10-10-2007, 08:17 PM   #69
Non-Reformed Meth Addict
Car: '06 WRB
IWSTI Addict since: Feb 2006
thanks again!
Glad it wasn't just me with the gnomes banging around in the trunk. Happy it worked for you.
Old 10-10-2007, 10:25 PM   #70
Glad it works out for you.
Old 10-15-2007, 06:18 AM   #71
i spent last weekend and this pasted weekend finding therattles, i closed out 4 rattles so far. still a few to go. my biggest is this rattle or play coming from front pass side. like the window is flexing or the fender... anyone?
Old 10-15-2007, 02:54 PM   #72
If it is that loud solitary "crack" sound the windshield makes when you make a right or left turn from a flat surface onto a steeply inclined surface, I don't think you can fix that. It is the windshirld flexing. If it is a rattle, then it probably is fixable. Good luck!
Old 10-23-2007, 07:57 PM   #73
Fav Mod: Stage 2 :D
FYI guys, the WD40 down into to top seal of the rear windshield did the trick for the mystery rattle at the rear of my car. couple weeks now, couple of car washes, still no rattle. Thank GOD we found it!
Thanks Fast08 for finding that one!!
-HC
Old 10-23-2007, 08:07 PM   #74
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
IWSTI Addict since: Jun 2004
Trader Rating: (14)
The lower section of the steering column cover makes a rattling/cracking noise. If you stuff some foam or something in there to prevent it from moving when you go over bumps it will fix it.
Old 10-23-2007, 08:52 PM   #75
i'll look into that, i just got my steering column replaced 4 months ago, the noise started about one month so it's a good chance
but i'm 100 sure it's either coming from my a pilliar, upper front door trim, windshield, fender lol that damn corner...to bad i have no one to trust driving my car to check myself
