Old 07-04-2007, 10:16 PM   #1
Car: 06 black wrx sedan
Fav Mod: TURBO
IWSTI Addict since: Aug 2006
Send a message via AIM to vroompssh Send a message via MSN to vroompssh
Default Gauges
what would be the best three gauges to run
i was thinking:
boost
oil press
and EGT
and would you guys say that prosport is a pretty good brand?
vroompssh is offline   Reply With Quote
Old 07-04-2007, 10:34 PM   #2
1B4DSTI
Fav Mod: M&J Modified
IWSTI Addict since: Jan 2006
Default Re: Gauges
the three gauges are fine, but i would go with defi
Old 07-04-2007, 10:41 PM   #3
Fav Mod: TURBO
Default Re: Gauges
i was looking at them two but they are also 200 bucks more.. what makes them above and beyond
Old 07-05-2007, 12:06 AM   #4
Fav Mod: 05 Tails, Protune
IWSTI Addict since: May 2005
Send a message via AIM to Pastapuck
Default Re: Gauges
I've heard Prosport's are pretty good. I run Defi's. Look into getting a wideband air/fuel in the future.
Pastapuck is offline   Reply With Quote
Old 07-05-2007, 12:23 AM   #5
Car: 08 CBR1000RR
Fav Mod: None
IWSTI Addict since: Jun 2004
Default Re: Gauges
I would say the most important three gauges are: Wideband, EGT, Boost.
You can check these out. Group buy going on right now from what I'm hearing. Defi are nice, but expensive.
MadDad(TM) Ultra Gauges - GB begins
Old 07-05-2007, 12:43 AM   #6
IWSTI Addict since: Mar 2007
Default Re: Gauges
I also would go Defi...I have 6 of them that I'm gonna install...I went with it due to the match interior of my WRX Green backlite and red needle...also it has a glass len over plastic which can easily crack...
Plus quality is bar none...
SoGoneRG is offline   Reply With Quote
Old 07-05-2007, 09:35 AM   #7
Car: 08 CBR1000RR
Fav Mod: None
Default Re: Gauges
You might also check this out: http://www.plxdevices.com/products/dm100/
One gauge you can customize with your pc, LCD quality, and can read up to four gauges live all at once. You have to order modules for each thing you want to monitor, but by the time you end up purchasing Defi's the cost for this maybe cheaper in the long run or at least be quite comparable. Plus you only have to look at one gauge and not 4, unless you want to buy more of the gauges. If you click on "products" on the page and go to "iMFD sensor modules" you will see what the costs are for the sensor modules. I think they are quite reasonably priced.
Old 07-05-2007, 09:36 AM   #8
Car: 05 Aspen White STI
Fav Mod: Defi Gauges
IWSTI Addict since: Jul 2006
Send a message via AIM to STI_Mike
Default Re: Gauges
That sounds good thats wat im running but im missing 2 of them
STI_Mike is offline   Reply With Quote
Old 07-05-2007, 07:06 PM   #9
Iron Fisted
Car: '05 STi
Fav Mod: Sparco seat
IWSTI Addict since: Sep 2006
Default Re: Gauges
Good choice of gauges. But look into getting a wideband someday. Prosport is good from what I hear, but I really like Defi.
