Old 03-24-2005, 06:49 PM   #1
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
Well before I jumped in and converted my OEM boost gauge to red, I did a search on here to see if I could find some pictures of what I was going to get myself into. I didn't find any threads with pictures or complete instructions, so I figured I would put pictures of mine up...I know it's fairly simple, but I'm sure there are others out there who wouldn't mind seeing these for future reference.
First of all, let me say that the rubber housing around the boost gauge has a really, really good grip on the gauge. It took some time, a few flathead screwdrivers, and some sore thumbs before I got the gauge out of there...
When you are getting the screwdrivers in there, you need to stretch the rubber housing and stick the flathead in (if you don't stretch it by hand, the screwdriver won't make it very far in there). Also, avoid putting a screwdriver at the top (12 o'clock position) as the power connector is there and you don't want to break it. I didn't know this until I had the gauge out, so avoid that mistake. One last picture with the white gauge, just so people can see the difference...
After the gauge was out, I unplugged the brown power connector (it is at the top of the gauge, just a simple push and it slid right off). There is a small black piece under this power connector - it holds the bulb. Turn it counter-clockwise (if you are facing the back of the gauge) and with about a quarter-turn it will come out. Pull it straight out - the OEM gauge has a blue bulb condom on it. I tried to pull the condom off without tearing it, but it's very thin and rips easily.
The hole in the picture below is where the bulb came out of (sorry, it's a crappy, blurry picture)
The red bulb condoms (ordered from parts express, these are the ones I bought) are a little longer than the bulb, so I had to cut off about 1/4" from the end.
All ready to go back in...
Line the gauge up with "TURBO" horizontally (unless you want to rotate it...) and then push it back into the rubber cup. Here's how it turned out:
Yes, the red needle on the boost gauge is a bit hard to see, but the white lighting on the boost gauge used to glare a lot, and this is much easier on the eyes at night.
Old 03-24-2005, 08:34 PM   #2
Sold My Soul For Mods
Car: '05 CGM STi
Fav Mod: Track Time
Trader Rating: (12)
nice work, that looks really good.
Old 03-24-2005, 08:36 PM   #3
Thanks for the writeup! I'm definitely gonna do this mod.
Old 03-24-2005, 10:01 PM   #4
Car: Black 04 WRX STI
dude you are the reason I save money and grow balls to do things like this = ) thanks man Thumbs for kick ass write up
Usdmsti is offline   Reply With Quote
Old 03-25-2005, 04:40 AM   #5
sponge worthy
Send a message via Yahoo to gixxer6
cool, looks good i think i'll try this too. thanks for the write up this should be a sticky
gixxer6 is offline   Reply With Quote
Old 03-25-2005, 04:58 AM   #6
Fav Mod: Brum Brum
2007 Postwhore King
Default Re: RE: evil car
Thanks guys, I figured I'd show some of the others what they are getting into
I added some tips regarding the screwdrivers - don't put one up at the top (12 o'clock, above where it says "TURBO") because the power connector is up there and you don't want to accidentally snap it with a screwdriver. 15 hours later and my thumbs are still sore from pulling on that rubber housing
Old 03-25-2005, 06:27 AM   #7
Trader Rating: (70)
Send a message via AIM to Paperchasin
good job!!! i would've gone with an omori 45mm gauge myself, since its already red lit and slightly larger....
Paperchasin is offline   Reply With Quote
Old 03-25-2005, 06:33 AM   #8
Fav Mod: Brum Brum
2007 Postwhore King
Default RE: Re: RE: New tires on ride but I got rubbing!
My car came with the OEM boost gauge, or else I would have saved up for the Defi BF's...I figure this is a good middle-ground solution, and I don't have to put up with that annoying white glare anymore!
Old 03-25-2005, 07:12 AM   #9
Send a message via MSN to kat398
Default Re: RE: turbo timer?
cool.
kat398 is offline   Reply With Quote
Old 03-25-2005, 07:38 AM   #10
Trader Rating: (70)
i kno wut u mean.... but wut i meant was that u could squeeze an omori 45mm gauge into that lil cup if u wanted to and replace that quarter-sized gauge...
Old 03-25-2005, 10:52 AM   #11
Car: 05 STi PSM 12.7 @
Fav Mod: Fujitsubo RM-01A hands down!
This is a great write up. I will be doing this soon.
Paperchasin: I like your idea of squeezing in the larger omori gauge in there as well. If it's an easy unplug and plug n go then I'll probably do it.
SpeedFactory is offline   Reply With Quote
Old 03-25-2005, 11:28 AM   #12
Car: 05 wrb sti
Fav Mod: cf hood
def. should be a sticky .. thanx for the writeup .. immma start this mod rite away
stiLLMELLO is offline   Reply With Quote
Old 03-25-2005, 01:14 PM   #13
Car: 05 silver/silver STI
Send a message via AIM to 05SilverSTI
looks good. thanks for the writeup.
05SilverSTI is offline   Reply With Quote
Old 03-25-2005, 03:02 PM   #14
definately doin it to mine
slow_sti is offline   Reply With Quote
Old 03-25-2005, 03:28 PM   #15
Fav Mod: Brum Brum
2007 Postwhore King
Not sure how easy swapping the Omori gauge in would be. That thick black line at the bottom of the gauge is a vacuum line (I believe), so if the Omori gauge also uses a vacuum line, and you can get the old line off easily, then I'd say it's worth a look. I'm happy with the look of the stock gauge for now...if I feel the need for a bigger one I'll be going with the Defi BF
