Old 11-17-2005, 09:02 AM   #46
OT stealth mod
Car: 06 obp sti
Fav Mod: Vodka injection.
Send a message via AIM to dailydriversti
bluebaru02 perfect description, i used some red nail polish on the led, i put 3 coats on, after 2 it was still a little light colored, so i put a 3rd, in the day light of course you can't tell its red, but at night turn down the dash one notch and it matches the boost gauge perfectly now, it took me about 20 min. to get it out, about 5 min. to get it in, pretty easy to do. actually i think this was easier than the key ring mod, that was a pain.
dailydriversti is offline   Reply With Quote
Old 11-18-2005, 06:40 AM   #47
Can somebody post some pics of the 06 boost gauge with painted LED?
DriveFast is offline   Reply With Quote
Old 11-18-2005, 06:50 AM   #48
OT stealth mod
Car: 06 obp sti
i should have taken pics, but my camera is MIA, its faily easy, just take your time, pull it out, disconnect everything, then i used a screw driver and pryed on the edges of the black ring on it, get the ring off, then i will all come out, unscrew the two bolts on the back, then the board will come back, there is a white little square sponge looking thing in it, if you don't know where the light is, i plugged the board back into the power, then turned my lights on, it will light up. then you know what you have to paint, paint until you get the desired red color to light, by plugging it back in, and turing on the lights. then finally installation is reverse of removal.
edit: i see what your talking about now, turn your lights on, full bright (dash lights) then turn them down one click, and mine is a perfect match to that. i will see if i can find my camera tonight, unless someone esle gets them.
Old 11-18-2005, 07:58 AM   #49
Car: 05 AW STi
Send a message via AIM to STiLLsLow
Does anyone know if this is the same procedure on the optional factory 3 gauges in the gauge pod?? Sounds like do the same process to all 3 gauges but just wondering if anyone has done it before? Great write up none the less..Thanks!
STiLLsLow is offline   Reply With Quote
Old 11-18-2005, 08:02 AM   #50
OT stealth mod
Car: 06 obp sti
Originally Posted by adidaSTi
Hoes anyone know if this is the same proccedure on the optional factory 3 gauges in the gauge pod?? Sounds like do the same process to all 3 gauges but just wonering if anyone has done it before? Great write up none the less..Thanks!
i wouldn't know, but i don't think i'm a hoe...or wait, 1,2,3,4,5,28,29....ok, maybe i am
Old 11-18-2005, 08:16 AM   #51
Car: 05 AW STi
LOL! my bad i meant DOES *
Old 11-19-2005, 12:33 AM   #52
Originally Posted by Ol'SaltyBastard
I swapped in the Omori gauge in the stock gauge housing. PITA for sure!!! Also, you really have to get the gauge in fully, or else the back part of the steering wheel will hit the gauge face (ask me how I know this.) The bonus is that I now get to read boost in PSI, and not some inferior metric reading.
Which Omori Gauge?
USA 79S is offline   Reply With Quote
Old 11-19-2005, 08:06 AM   #53
OT stealth mod
Car: 06 obp sti
Originally Posted by USA 79S
Which Omori Gauge?
45mm link for write up i believe, my home comp isn't working too well so i can't view it
Old 01-13-2006, 11:45 PM   #54
Banned
Car: 04 UbaR STI
Fav Mod: Call out her best friends name, and see how long you can hang on !
Send a message via AIM to QualityOregon
I went to go order a red condom, and its 1.50 + 9.00 for shipping, wtf is that about, ill just wait for my defi set.
QualityOregon is offline   Reply With Quote
Old 01-19-2006, 03:20 PM   #55
ALi
Car: 2004 Australian Vers
can i do this to my White Defi sets? if yes, pics please. I always want to make the gauges amber. any chance? beside buying amber ones?
ALi is offline   Reply With Quote
Old 01-24-2006, 04:45 AM   #56
Indiatr0n in yo IWDPL
Fav Mod: Brum Brum
2007 Postwhore King
I don't have Defis, so I have no idea, but I certainly wouldn't risk taking apart those expensive gauges...something tells me the Defis are illuminated by more than just one LED
Old 01-28-2006, 11:37 PM   #57
Fav Mod: Junior Tuned
Send a message via AIM to boostedrex05
lol i just took my gauges apart today seeing what i needed to do to make my gauges in my dash pod light up red to match my defi a pillar gauges. thanks for the page to buy the condom's lol there to small thow this might be a little of topic but does laMco make a psi boost gauge i would like to buy one n ditch the bar form gauge you know..
boostedrex05 is offline   Reply With Quote
Old 01-28-2006, 11:49 PM   #58
Fav Mod: Brum Brum
2007 Postwhore King
Omori makes a PSI boost gauge, look at posts earlier in this thread
Old 03-28-2006, 11:46 AM   #59
Car: SGM '06 ReX
Fav Mod: Boxer Rumble!
Send a message via AIM to TheAn$wer
Nice write up, i know im kinda late lol... but i have an 06 and i tried this and i think the boost gauges are different because i cant even get to the bulb... its weird... ive done interior bulbs on a few cars, and on my 06 theres harness thing for the bulb to turn left or right to get it out. Its just the power unit conects to the gauge and theres the line for the actual boost... thats all there is, i just remembered i shoulda taken a pic before i put it back in, oops...
TheAn$wer is offline   Reply With Quote
Old 03-28-2006, 12:01 PM   #60
OT stealth mod
Car: 06 obp sti
the answer is there, you have to take the gauge out, pry on the black ring on the front of it to take the glass out, then unscrew the bolts on the back of the gauge. seperate the gauge back from the case, look at the little board inside of it, there is a little white sponge looking thing in it, paint that with nail polish.
