| Junior STI Driver | Well I finally did it, got the clock mounted in the ashtray since i've got the dash gauge pack. it was actually easier than i thought, just had to file down the tabs on the side and it fits right in nice and snug without anything to hold it in. ![]() Here's the install... Since my gauges were port installed i didn't have a clock to begin with and had to order one. ![]() file down the tabs on the sides so that it'll fit in the ashtray slot ![]() Pull up the trim around the shifter by prying up on the edge behind the shifter ![]() then undo the two phillips screws below the hvac controls and pry away the radio trim peice ![]() there are three screws under the vents you'll have to unscrew to get that off ![]() after that's off, reach back and find the clock plug. mine was behind the vent and ziptied to that black and white set of wires. i used another ziptie to keep those neat and tidy after freeing the clock wire ![]() cut away the electrical tape to expose the 4 wires going to the plug ![]() i used these crimp connectors to extend the wires down to the ashtray, but if you're handy with a soldering iron, more power to ya ![]() here they are coming out of the ashtray and attached to the plug ![]() if you had some different colors of wire it'd probably be a little less confusing, but i just did one at a time so i couldn't screw it up ![]() then just plug the clock in and push it into the slot where the ashtray used to be, should fit nice and snug ![]() Enjoy! Rutch 8) This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #5 | ||
| So Gangster It Hurts Car: 1994 & 2005 Legacy G Location: Bothell, WA Posts: 4,079
IWSTI Addict since: Jul 2003 Trader Rating: (0) | Quote:
| | #13 | |
| Silver Member
Car: 05 Subaru WRX STi Fav Mod: DB 20G, Diamond Black BBS RE's, S2K retrofit Location: NY Posts: 4,632
IWSTI Addict since: Jul 2004 Trader Rating: (7) | Quote:
nice writeup btw | |
| | #14 |
| Junior STI Driver | for all the smokers who actually use their ashtray, there's another writeup on how to put the clock in the coin tray in front of the fuse box. but i don't think it's as visible down there http://www.scoobymods.com/forums/showthread.php?t=521 that's where i got the idea to put it in the ashtray. really you could probably put it anywhere you want as long as you want to run wires there ![]() Rutch |
| | #15 |
| Spec C Club | ouch man, thats a lot of money... next time, or future modders... look in NASIOC for crashed cars part-outs... This ad is not endorsed by this member. Please register or login to hide this ad. |
