Old 12-20-2006, 10:21 AM   #121
Car: '05 STi WRB
Send a message via AIM to IceWilly
well i used pipe foam, so the thickness was the same, i didn't trim it down at all. I made one side of the bolstering in the right shape, flipped it over and trimmed the other side to match it mirrored. if it was too high in places or too low i pulled it out and trimmed a little more. Thickness wasn't my concern, but i wanted the shape to match up nicely with the side of the seat. 1 layer on each side of the 3/8" or 1/2" don't remember was enough extra thickness.
btw since ive done it the top strips i added to extend the spine... have started to move around, basically sliding towards the outsides of the seat, especially bad on the door side. You may want to pin them or glue them down or something. The inside angled ones haven't moved at all though.
IceWilly is offline   Reply With Quote
Old 12-20-2006, 11:04 AM   #122
Car: 06 AW STI
Fav Mod: Hardwired 8500
yeah the foam i have is 1/2 inch. i can see how the spine bolsters will slide. seems like the limit is one layer. i have 2 layers of 1/2 inch, and while it fit and felt awesome. it created a huge wrinkle. the problem is that it lifts the seam of the black and blue fabric too high so the blue suede is floating instead of held against the back. i think if youre like me, and need more than 1/2 an inch on a side u have to make do or buy new seats.
NorCALSpeed is offline   Reply With Quote
Old 12-20-2006, 06:56 PM   #123
Fav Mod: Junior Tuned
Send a message via AIM to boostedrex05
Originally Posted by Curryboy
Yah but you lose the airbag then. I'd rather be alive then comfortable any day.... the crash rating was one of the reasons I chose the subaru over the mitsu.
It helps that I like the STi in every other aspect, but safety was undoubtedly a contributing factor....
lol half the time air bags are defalty and just dont deploy so just try not to get t boned lol
boostedrex05 is offline   Reply With Quote
Old 12-24-2006, 04:04 AM   #124
Car: 07 Sti Ltd
Fav Mod: x-brace :-)
Originally Posted by STiSpeed
So what is the best material to use for this that will not compress over time?
high density, closed cell foam. If you are using pipe insulation, they make two kinds. The grayish one and the dark gray, almost black one. The darker is the higher density. (But harder to find, you'll have to go to a real plumbing supply house, not home depot to find it.)
Some craft shops have low density open cell foam. (the yellow kind that squishes when you compress it.)
If you really want the right stuff, find a custom upholstery shop in your location and they have the best foam to use.
StiLimited is offline   Reply With Quote
Old 03-17-2007, 01:48 PM   #125
Car: 05 wrb
Kinda bringing this back from the dead.... i FINALLY got around to putting the foam in my stock seat and putting stock seat back in the car.
Honestly, very litlte improvement :-( , I am dissapointed... Sure, its a little better, but it still doesnt make up for the fact the seat doesn't have any shoulder bolstering at all, and that the seat is overly springy.
So the fatter bolsters are actually touching me when i sit in the seat now, but going around a corner, since there is no shoulder bolster at all, my shoulders move right off the seat, and my lower body just slides right up over the side bolster.... the only way i can semi-stay planted is to crowch way down, basically sliding my butt further forward on the seat, lower back just kinda in the air, and have my shoulders start to tuck down in the lower bolsters a little.... as you can imagine, that is not very comfortable....
I'm starting to think of getting a corbeau CR1 and taking to a custom apolstery shop and seeing if they can retrofit the airbag in there or something.... but for now, i might just buy some scroth wrx harnesses to see if they will help at all...
BTW I am 5'6" and 135 to 140lbs... (earlier i said 5'7" which was a bit optimistic haha, and I got sick and lost weight since then).
How is everybody elses seats holding up?
Tomasu is offline   Reply With Quote
Old 03-18-2007, 12:28 PM   #126
Car: 06 STI - SGM
Fav Mod: HPDE
Tomasu,
Try stretching the seat springs in the bottom and back. I did this and it changed the seat a great deal, as I now sit in the seat as opposed to on the seat. Now, this isnt a miracle cure, but helped a great deal.
I'm 6'4" and 210lbs.
Be good,
TomK
ace996 is offline   Reply With Quote
Old 03-18-2007, 01:43 PM   #127
Car: 2006 - CGM
Originally Posted by ace996
Tomasu,
Be good,
TomK
I stretched the springs and added some closed cell foam. I didn't add any foam to the seat bolsters. I ended up taking the foam out of the seat back, as it seemed to pushing me too far forward. Its true, I do sit more "in" the seat than before but the seat back is still a big problem. As Tom describes, not enough side bolstering to keep you in the right place.
Old 03-18-2007, 10:04 PM   #128
Car: 05 wrb
I think I'll try to stretch the springs some more when i get a chance... I have stretched them a little bit before, but still need to find a good technique to do it, since they're so friggin strong... How did you go about stretching them?
Old 03-20-2007, 06:31 PM   #129
Car: 06 STI - SGM
Fav Mod: HPDE
Pliers. Just plain pliers and a few good tugs...reminds me of my honeymoon. Yeah...good times.
Be good,
TomK
Old 08-22-2007, 07:11 PM   #130
Scoobie Dooby Doo
Car: Is freaking fast!!!
Fav Mod: Going turbo
Default Re: Modify your stock seats!
You could use this stuff,
http://www.seatfoam.com/
scoobster is offline   Reply With Quote
Old 08-23-2007, 05:15 AM   #131
Car: '05 STi
Fav Mod: Spec C roof vent
Send a message via AIM to mykrrrr
I'd like to see how much you can take out of the seat bottom to get you lower in the car. I currently have my Sparco EVO2 in there but it'd be nice to have SAB's again.
mykrrrr is offline   Reply With Quote
Old 10-28-2007, 06:47 PM   #132
Fav Mod: 20G
Back from the dead! Just did this today. Only got the upper part done as I could not figure out how to get the seat cushion cover off... any tips?
KruxSTi is offline   Reply With Quote
Old 05-18-2008, 11:43 PM   #133
Car: 07 obp sti
Fav Mod: endura-tech's
Send a message via AIM to sti* fan
just did mine today as well i picked up some pipe foam insulation for $2.50 at home depot. i only did the upper side bolsters since i was mostly lacking latteral support. the whole process took me about 30 minutes total the air bag side was much harder to get into tho. i went for a drive right after and took some turns i normally take hard and i can say the improvement was easily noticed i can feel the side bolsters pretty much all the time now. before i would have to lean before getting into the turn and not so much now I feel much more confident taking those harder turns.. overall im very happy with the results and now ill just have to wait and see if any issues pop up..
sti* fan is offline   Reply With Quote
Old 07-21-2008, 06:04 PM   #134
Car: White 06 STi
Fav Mod: Forged Bypass
Send a message via AIM to ilami01 Send a message via Yahoo to ilami01
****tiest how to ever!
ilami01 is offline   Reply With Quote
Old 08-04-2008, 09:55 AM   #135
Car: '06 OBP STi
Fav Mod: Driver's Ed
I removed the top two seat back springs last week before a short road trip (left the bottom spring in for some lumbar support). Immediately noticed I sink back into the seat more, and the side bolsters on the seat back "feel" taller now! Got home and decided to do something about the seat bottom before another road trip. Used zip ties to secure the rear spring to the rear support bar and the front spring to the front of the exposed frame. Essentially eliminated the "spring" action, but they're still there to support the foam and fabric. Made a HUGE difference driving from NC to AR. I now sit deeper down and back into the seat, and I'm no longer budgeting for a new seat! Can't say that "bobblehead" is gone, but what bounce is left gets blamed on my suspension.
cekeel is offline   Reply With Quote
