Old 06-29-2008, 06:14 PM   #1
Car: 06 wrx ltd vf34
Fav Mod: JTAG
Default when i crank the engine, radio and gauge go off and back on
hi,
i have an alpine and defi racer gauges...
how come when i crank/start the engine, they go off instantly and come back on rite away? is this normal?
bzbuzz is offline   Reply With Quote
Old 06-29-2008, 06:18 PM   #2
Car: Silver 08 STI
Default Re: when i crank the engine, radio and gauge go off and back on
your radio and gauges are connected to a switched power supply. this is normal. you do not want the radio or other aux equipment on while the engine is cranking/starting.
cheers
jrdriller is offline   Reply With Quote
Old 06-29-2008, 06:36 PM   #3
Fav Mod: JTAG
really? but sometimes they stayed on tho...most of time go off..
Old 06-30-2008, 03:05 AM   #4
Car: 04 PSM STi
The gauge and radio are not on a switched circuit. Your battery isn't supplying enough amps sometimes to power them during the crank. You can try a voltage regulator, or a nice big capacitor, or a tank circuit. Or just buy a new battery.
wi77iam is offline   Reply With Quote
Old 06-30-2008, 08:20 AM   #5
Fav Mod: JTAG
my battery and alternator should be fine tho..
i checked the battery when car is off it is 12.9v and when cars at idle..it is 14.5
Old 06-30-2008, 04:19 PM   #6
Normal for the radio, but for the gauges it means you're tapped into the wrong power source. Try tapping into the power for the hazard button. Search on here for details, it's a regularly occurring installation mistake.
Old 07-01-2008, 04:35 AM   #7
Car: Silver 08 STI
this might help
Gauge Installation Electrical Wiring Tips and Pics Defi and Others - NASIOC
cheers
Old 07-01-2008, 10:30 AM   #8
Fav Mod: JTAG
Originally Posted by jrdriller View Post
I wired gauges based on that nasioc thread.
Old 07-01-2008, 10:44 AM   #9
Car: WRB EDM 06 WRX STI
Fav Mod: Aerys 3"
Originally Posted by bzbuzz View Post
hi,
same radio and same gauges (bf) same behaviour
torquemada is offline   Reply With Quote
Old 07-01-2008, 01:02 PM   #10
Fav Mod: JTAG
it seems like when you start the engine all(?) accessories go power off instantly to give enuf current for starter...so my alpine restarts and defi does sweep again....
i am still wondering if there is a way to have defi stayed on even if start the engine..
Old 07-01-2008, 02:15 PM   #11
Did you not read what I wrote? Do you need this handed to you on a silver platter?
defi wiring help!
Old 07-02-2008, 06:46 AM   #12
Fav Mod: JTAG
defi wiring help!
I did read it and didn't like it since i checked the schematic and it seems like that black/green wire on the hazard goes to the ignition relay instead of being fed directly from the power supply(i am using ign on the a/c harness). and it doesnt look like the wire is active when the harzard is on...did u try?
Old 07-02-2008, 06:55 AM   #13
Fav Mod: JTAG
after researching, my conclusion is that I dont think there is a way to make my defi's stayed on when i crank engine since i can't find solid 12v line that always hot. like i said eariler, all 12v lines drops when engine starts. this is not the issue w/ ign wire, but 12v line.
Old 07-02-2008, 02:10 PM   #14
This is how I set up my Defis. And they turned on with the ignition, and did not turn off and back on again with the key turned to start. It's a really common issue, with a really easy solution. My favorite kind of problem .
Old 07-02-2008, 04:51 PM   #15
Fav Mod: JTAG
let me ask you this..
so let' say your key is on 2nd position, your defi sweeps...and you start your engine..it doesnt sweep again?
