Old 06-25-2008, 10:16 AM   #1
Car: 06 Subaru WRX STi
Default Adjustable Headlight Not Working
This is on a 06 sti. I can adjust the left side works perfectly fine, but right side does not move at all. Is there are a motor or something that controls it?
BTW : Nothing has been modded on the headlight and both HID works.
Thx
STL06WRXSTi is offline   Reply With Quote
Old 06-25-2008, 10:55 AM   #2
Reasonable
Fav Mod: correct grammar
Default Re: Adjustable Headlight Not Working
Seized servo? Loose wire? Some sort of gunk in the mechanism?
Have you ever changed the bulbs?
Old 06-25-2008, 12:45 PM   #3
nope never change the bulb. I check all the wires everything sees tight.
Old 06-25-2008, 12:56 PM   #4
Car: 06 WR Blue/Gold STI
Thx
I had the exact same problem with my '06 right headlamp as well. Took it to the dealer and the headlight assembly was replaced under warranty.
futureficus is offline   Reply With Quote
