Old 06-02-2008, 07:56 AM   #1
Car: 2005 STI
Fav Mod: its all good!!
Default Instrument Cluster/tachometer speedometer malfunction
Washing carpet and later found out the instrument cluster malfunctioned.
Symptoms are:
Hear a slight audible siren or buzzing noise from under the dash.
Speedo and Tachometer start up when ignition switch turned on move very slowly.
Outside temp and odometer led lights flicker.
When driving rpm guage shows excessive rpm and maxes out even thoguh engine is barely turning over.
Speedo also shows max speed even though only doing a few clicks.
Guages are basically showing excessive values.
I removed neg cable, reset ecu and installed new map with accessport, no error codes showing all to no avail.
I heard someone else had this problem and the dealer had to reset the instrument cluster. Any idea how to do this?
sportytourer is offline   Reply With Quote
Old 06-10-2008, 07:07 PM   #2
Car: 2005 STI
Default Re: Instrument Cluster/tachometer speedometer malfunction
Ok fixed problem. Required to disconnect both positive and neg battery poles and wait a few secs. Instrument cluster will reset and be normal once battery is reconnected.
