Old 05-30-2008, 08:30 AM   #1
Fav Mod: Rustoleum Flat Black
Default Aftermarket Steering Wheel On 06' STI's (See Last Post For Final Outcome..)
This is kind of a "How-To" and a heads-up all in one. I have been at this little install for quite a while and have learned alot. Here goes...
I purchased the Team Orange Steering Wheel, Works Bell Quick-Release, and an NRG Innovations Short Hub.
I then started perusing the forums for How-To's and here is what I found:
Thanks ProDriveRex for this one...
Horn Hookup and Turn Signal Auto Canceling on Aftermarket Wheel *NRG Setup*
Thanks VIREURORALLY for this one:
Aftermarket steering wheel and quick release hub install
Both are quite helpful in many ways but, fail a bit on an 06' STI.
With my first attempt, I removed the airbag and steering wheel. The NRG hub would not seat against the clock-spring assmbly without rubbing and my horn did not work. Neither did my turn-signal reset because that had to be removed to accomodate the NRG hub as well.
I tried to search around online for help and ProDriveRex's post was sent to me by the nice gentlemen at GarageSpec.
With my second attempt at installing my new wheel, I removed the steering roll connector (aka clock spring assy.) And this time I fabbed up the "brush" in the link sent to me and got the horn working. I also did the taped on turn-signal reset fix. Ugly, but it works. Upon starting the car a new problem appeared. My DCCD was dead.
Now I am in a panic and purchase the Subaru Service Manual Section 8 "WIRING".
I guess this is the How To part...
The Steering Roll Connector in the 06' and Cruise Control circuit are where I will focus.
First the Cruise Control. It is plugged in under the dash with a 5-pole, black connector. (#B68) The red/green wire in pin 1 is your horn. This can be used for powering up the horn circuit. The other four wires are for the crusie control. Each of these is basically an "open" until a switch on the cruise control stick is pushed and then the circuit is closed. These will not cause any problems when removed.
The other piece of the steering roll connector is actually two pieces. (Two halves if you will) The first (top) piece is the clock-spring for the airbag. It has a yellow wire extending from it ending with a yellow connector. It is a 4-pole, yellow connector (AB26). It connects to (AB21) a connector under the dash that lead to the Front Sub Sensor for the LH side of the vehicle. Again, when removed it causes no problems except for the airbag light in the dash.
The second half of the steering roll connector is the problem area for 06' STI owners. I found out the hard way. The pictures below show what I found out to be the "Steering Position Sensor". This sensor is screwed together with the clock spring. It had a white lead ending in a white, 4-pole connector (B426). This is actually part of the DCCD circuit and feeds steering inputs to the Yaw Rate & Lateral G sensor in the DCCD control module. Removing this leaves your DCCD stuck in full open and your driver controls are lost.
99% of the facts are in and a Works Bell or similar hub is necessary on the 06' - 07' STI.
Removing the steering-roll connector for any reason will disable your DCCD. Don't do it.
Stupid Subaru changing things every year or so...
*EDIT: See last post for more new information. This subject has concluded*
grambo is offline   Reply With Quote
Old 05-30-2008, 01:46 PM   #2
Default Re: Aftermarket Steering Wheel On 06' STI's
You could have just used the Works Bell hub (short or regular) and saved yourself some headache =) ... Everything bolts on, no problems.
nevermind, i saw at the bottom you just bought it.
lunatictokyo is offline   Reply With Quote
Old 05-30-2008, 02:16 PM   #3
Car: 05 WRX STi
I guess this problem only for 06-07's? It seems 04-05's are safe as my DCCD does work...
Old 06-02-2008, 06:26 AM   #4
Yeah, that has been verified and my vendor is hooking me up pretty quick here. After that it'll be a matter of repairing the clock spring wiring and I will be fine I think.
As far as I can tell, most folks that have done an NRG hub on an 04-05 haven't had a problem. I have done lots of searching before posting up and really tried to only include facts that I could verify...
Old 06-03-2008, 09:07 PM   #5
Car: 06 Subaru WRX STi
Fav Mod: seatbelt beep delete
its because the pre '06 didnt have a steering wheel angle sensor
06AspenWhiteSTi is offline   Reply With Quote
Old 06-04-2008, 06:28 AM   #6
Knowing very little about the subtle differences between an 04-05 and my 06, I was forced to do the research and find out for sure. Hopefully this can help the next dude that decides to upgrade his steering wheel.
Old 06-09-2008, 08:03 PM   #7
Send a message via AIM to jermdeez
what is that for?
jermdeez is offline   Reply With Quote
Old 06-13-2008, 08:06 PM   #8
Car: 05 sti...
Fav Mod: I Love my STi stickers!
Send a message via AIM to dlouie87 Send a message via MSN to dlouie87
05 is ok right? problem free
dlouie87 is offline   Reply With Quote
Old 06-22-2008, 09:24 PM   #9
Car: Car Builder
Fav Mod: Boost
Send a message via AIM to token-negro Send a message via MSN to token-negro
Bump for more info on the works bell hub, dont leave the 06 people hanging here, this thread has the chance to have usefull information.
token-negro is offline   Reply With Quote
Old 06-26-2008, 11:03 AM   #10
Originally Posted by jermdeez View Post
what is that for?
The steering angle sensor tells the DCCD Module what position your steering wheel is in during a turn. Its just another input for the AWD to make "decisions" with.
Old 06-26-2008, 11:04 AM   #11
Not sure about 05's. Some state that it does not have the Steering Angle Sensor. I dont know for sure.
Old 06-26-2008, 11:07 AM   #12
So, you went with an 06' after the crash. Good stuff. Sorry about your old car though...it was so nice.
Anyway, I will update accordingly when I get the Steering Roll Connector I just bought.
Most expensive friggin steering install in history....
Old 07-01-2008, 08:58 AM   #13
UPDATE
All of the theories aside. The proper hub for an aftermarket steering wheel on an 06' or 07' STI is the Works Bell or similar. The NRG Innovation style hub will NOT work on an 06' or 07' STI.
Removal of any part of the steering roll-connector assembly disables the DCCD.
Thanks to: Ed and John at GarageSpec for being supportive and understanding. Thanks to jdmdave for offering to rip apart his car to help. Thanks to the "Electrical" section of the Subaru Maintenence Manual for good wiring diagrams...
Old 07-01-2008, 12:50 PM   #14
Fav Mod: Tank the Terrier!
Send a message via MSN to RAPTR
Default Re: Aftermarket Steering Wheel On 06' STI's (See Last Post For Final Outcome..)
Moderator this should be a sticky!!!
RAPTR is offline   Reply With Quote
Old 07-10-2008, 01:33 PM   #15
Car: Car Builder
Fav Mod: Boost
If we had more information about, why the works bell unit works, how to identify other brands that might work those would be pretty helpfull.
