Old 04-30-2008, 02:30 PM   #1
Reasonable
Fav Mod: correct grammar
Default Question for DEFI users
I'm going to be installing a Defi BF Amber Oil Temperature gauge shortly. I understand that there are two ways to install the sensor. One is to replace the stock galley plug in the block, and the other is to run it from an oil filter sandwich adaptor.
Questions:
1) Would someone be so kind as to give me a part number or link for the 1/8 NPT -> 1/8 BSPT adaptor for the galley plug, since the one I ordered is too narrow to allow the sensor rod to thread through.
2) Would someone be so kind as to give me a part number or link for the oil filter sandwich adaptor that I will need to install this piece. I was planning to do the engine block install, but I'm over it. Either way is fine.
I've gone round and round trying to find this stuff and cannot find a definitive answer.
Old 04-30-2008, 04:13 PM   #2
Car: 05 Aspen White/Gold
Fav Mod: Öhlins FP
Default Re: Question for DEFI users
Do you have the Imperial or Metric Oil Temperature gauge?
The metric one you can use the Subaru Oil Galley Plug as it accepts the 1/8 BSPT.
But if you have the Imperials then you'll need to get a galley plug thats been retapped to 1/8 NPT.
I was confused about this myself, but I'm going to install my Oil Temp in the oil galley plug below the intercooler. And I bought this plug from WRXTRA
As far as sandwhich adapters, if your just installing the oil temp I say use the oil gallery plug.
alphaSTI is offline   Reply With Quote
Old 04-30-2008, 04:18 PM   #3
Reasonable
Mine is Imperial. Thanks for the link.
Old 05-01-2008, 05:45 AM   #4
Fav Mod: Do Luck CF
I have the Greddy oil sandwich adaptor plate and it works just fine. Most of them are universal. It has a pre drilled/threaded hole for the Defi sensor without the need for any adaptors. I got mine from WorldOne but here is a link:
RallySportDirect.com - Greddy Oil Filter Sandwich Block Adapter
Old 05-01-2008, 05:53 AM   #5
Reasonable
Old 05-01-2008, 05:53 AM   #6
abracious
Fav Mod: Track time
FWIW:
The galley plug is M18x1.5.
Imperial Defi's use 1/8 NPT threads, metric use 1/8 BSPT.
Old 05-01-2008, 05:56 AM   #7
Reasonable
Originally Posted by fullerton View Post
FWIW:
^Aware of that. Thank you.
Old 05-01-2008, 06:04 AM   #8
abracious
Fav Mod: Track time
Just posting it for future readers.
Old 05-01-2008, 06:07 AM   #9
Reasonable
Understood.
Old 05-01-2008, 06:41 AM   #10
STI Guru
Fav Mod: Whooshing sounds
There you go:
WRXtra
We both have the same problem. My Maddad oil sender is NPT as well and the Subaru galley plug is BSPT.
To make matters worse, the sender is too big to fit in that area, so I bought the relocation kit for it.
I think you'll be fine with the modified plug they sell.
Peleg is online now   Reply With Quote
Old 05-01-2008, 02:22 PM   #11
Fav Mod: Do Luck CF
Anytime, pal.
Old 05-01-2008, 04:31 PM   #12
Car: BLOBEYE SYNDICATE ST
Fav Mod: N-E thing JDM
I agree.. I used the sandwich adapter
twilight_samurai is offline   Reply With Quote
Old 05-01-2008, 05:19 PM   #13
Car: My06 WRB w/ Gold STi
Fav Mod: JDM Headlights and JDM Rear Fog
There are so many ways to do the oil senders just pick and choose
WRB Kid is offline   Reply With Quote
Old 05-02-2008, 03:56 AM   #14
abracious
Fav Mod: Track time
Have you ever had problems with it?
It has been recommended to my by several "authorities" to avoid the sandwich adapter route.
