| Silver Member
Car: 2006 OBP STi Fav Mod: Snow Location: Alberta Posts: 1,469
IWSTI Addict since: Sep 2006 Trader Rating: (7) | Now that it's getting cold around here, I have to use the heater more frequently...high of 9F today. Problem is, in the mornings I get a sheet of frost/ice on the inside of the windshield and windows. Is this due to a bad window seal somewhere or should I be using the ac system when I use the heater to get rid of the moisture? I can deal with frost on the outside, but i hate leaving the car running for 5 min just to get the inside of the windows to de-frost.Suggestions? This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #3 |
| Grassroots STI Racer
Car: 2004.3 PSM STi Fav Mod: JDM STi Performance Muffler Location: NJ Posts: 566
IWSTI Addict since: Mar 2004 Trader Rating: (0) | Could be a seal. However, I've seen quite a few cars fog up on the inside due to a window accidentally being left open while it was raining. The moisture in the carpet/seats/floormats/etc usually doesn't evaporate immediately and causes condensation on the inside of the car. Not sure if this is relevant to you, but its one of the probable causes. |
| | #5 |
| Spec C Club
Car: 07 STI LTD/08 STI Fav Mod: APS/Crawford/Cosworth/Aquamist Location: E-town, AB Posts: 2,373
IWSTI Addict since: Apr 2005 Trader Rating: (5) | Ice/Frost inside the car?? I've never seen that on any car. You just mean fogging up right? |
| | #6 |
| Silver Member
IWSTI Addict since: Sep 2006 Trader Rating: (7) | Yeah, it fogs up, then after it sits overnight that fog turns into ice. |
| | #7 |
| Spec C Club Car: 05 STi - Black Fav Mod: No Lien Location: Ontario, Canada Posts: 1,950
IWSTI Addict since: Mar 2006 Trader Rating: (2) | Hey dude, come on, you're around F18's all day, you should know about condensation nuclei ![]() For frost to form, the moisture needs to latch onto something in order to condense - ie dust or dirt. 1st thing, give the inside of the windows a thorough cleaning. That will help a lot. 2nd, do you have a garage? If so, leave a window cracked open during the night. Frost also forms because the moisture given off by your body, or melted snow in your floormats is trapped inside the car and condenses on your windshield. Cracking a window equalizes the humidity with the outside air. 3rd - as others have said, change your cabin filter - lessen the dirt that I mentioned before. |
| | #9 |
| Amateur STI Driver Car: White 06 STI no mods Fav Mod: hopefully stage2 soon! Posts: 19
IWSTI Addict since: Apr 2006 Trader Rating: (0) | I heard that if you rub Shaving cream onto your bathroom mirror it will never fog up after you shower. Does anyone want to try shaving cream in their car windows? |
| | #10 |
| A.X.D. | |
| | #11 | ||
| dances with roads | Quote:
| | #12 | |
| A.X.D. | Quote:
if the car is going to dry itself out, the best settings would be to use the AC, max heat, max fan, and recycle; this way, the AC keeps recycling the air that it has partially dried already and it will wick more moisture from the inside of the car. again, this is with the car running and no one in it. if you are in the car, and use the AC, i also use the outside air. | |
| | #13 |
| Authorized Vendor
Car: 04WRX /STi Swap Fav Mod: TiC AST Coilovers!!! Location: Tri-State, USA Posts: 1,311
IWSTI Addict since: Nov 2005 Trader Rating: (91) | I had some moisture all inside my car 2 days ago when it was raining alot. my central cluster had some condensation all over it, so the AC on full was used to evap everything This ad is not endorsed by this member. Please register or login to hide this ad. |
