Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > Innovative Automotive
Old 04-13-2004, 05:07 PM   #1
Send a message via AIM to IA Performance
Well, spring is in the air and I'm in the cleaning mood.
If there is a particular part you would like a photo of please feel free to email me at stephen@iaperformance.com.
I'm willing to swing a deal if you buy multiple items. I.E. A/C compressor, Alternator, PS pump all for $225 shipped.
Reason for all of these parts is that I really wanted a twin scroll turbo setup and the only way to try and do it economically was to purchase an entire motor. Doesn't quite seem right, spend more to save more
Paypal, check, cash and first born all accepted :P Please feel free to email me or PM me with any questions. If you feel in the mood feel free to drop me a ring for major questions 520-207-2494 PST.
Version8 Sti Take Off Parts
A/C w/ PS belt $8
A/C belt tensioner $15
A/C Compressor $55
Sti 90 Amp Alternator, US wrx is 75 $80
Bypass Valve $25
Coil Packs (4) have 2 sets $100
Coolant cast inlet w/ temp sensor $25
Coolant tank w/ water and breather tube lines $70
For those that are unaware of what tubes there are they are the much desired JDM tubes which plumb into the stock EJ275 breather hole. They also connect at AVCS heads.
Crank position sensor $10
Crank Pulley $30
Factory dampened model for high rpm applications
Heads w/ head bolts $1,999 SHIPPED
These heads have some of the largest factory ports that we've EVER seen! Larger than the version7 spec C even. Why waste time and money porting stock wrx heads when you can have sti cams, stronger springs, shimless buckets, and ultra high flow heads? These are perfect for all of you US sti 2.5L build up enthusiasts.
(2 sets) Sti Motor Mounts $55 per set SHIPPED
Oil Fill Neck $5
Power Steering Pump $120 SHIPPED
Short Block; Free items included today are
-Oil pump
-Water pump
-Coolant inlet pipe
-Coolant temp sensor
-Oil Temp sensor
-Crank sprocket
-assorted timing belt pullies
-$1,100 SHIPPED!!!!!!
Sti Throttle Body $100
Timing belt $50
Timing Belt sprockets/pulleys(ones cirlced) $50
Timing Belt Tensioner $50
Timing Belt Tensioner w/ v8 sti timing belt $75 SHIPPED
TMIC w/ Y hose & breather tubes SOLD
Excellent condition JDM STI Intercooler. This IC is 40% larger than the US-WRX and 14% Larger than the US-STI intercooler. Fits US 02-04 wrx without issueses unlike US sti TMIC
Turbo inlet pipe $20
Larger than stock wrx. Does NOT kink down like WRX one
Wiring Harness w/knock sensor. Identical to version 7 $100SHIPPED
Tearing down over this evening will be
Version7 Sti Parts
A/C and PS belts $8
A/C Compressor $55
Alternator SOLD
Breather tubes for heads $40
Bypass Valve $25
Coil Packs (4) $100
Coolant tank $30
Crank Pulley SOLD
Red Intake Manifold SOLD
Has minor scratches where the BOV goes. Once installed you won't even know they are there.
Complete v7 large port Heads with cam sprockets to boot $1,500
Knock sensor $10
Manifold Risers $100
Motor Mounts $55
Oil Cooler $30
Oil Fill Neck $5
Short Block w/ oil pump $999 SHIPPED Great price for factory FORGED internals. Yes, FORGED internals!
Timing belt covers (5)same as v8 ones SOLD
Timing Belt sprockets/pulleys $50
Timing Belt Tensioner w/ v7 sti timing belt $75 SHIPPED
(1)TMIC w/ Y hose & brackets $499
Up-pipe $175 shipped
Water pump $45
Stephen
IA Performance is offline   Reply With Quote
Old 04-14-2004, 02:45 PM   #2
Car: 05 Subaru WRX STI CG
Default Re: Ok guys... im screwed, need YOUR help!
pmed you, lmk when you get it.
Robert~
HTML code is On
