Old 10-01-2007, 06:06 AM   #1
Car: 06 sti wrb
Fav Mod: trading the svt for an sti
IWSTI Addict since: Nov 2005
Default bad fm reception from aftermarket radio ??
since i swapped my stock head unit to an aftermarket one (blaupunkt),the radio reception is about 30% of what it was with stock unit. on highway is no problem, but within the city, its not good at all (the stock unit was at least 3 time better). i`ve double checked the antenna and it is properly connected .
did i buy the wrong brand (blaupunkt)?
is it the same with all aftermarket radios?
should i have asked for a new antenna also ?
any advice is appreciated.
thanks
the ambush is offline   Reply With Quote
Old 10-01-2007, 07:14 AM   #2
Car: 06 Subaru WRX STI
Fav Mod: air freshener (mmm...squash)
IWSTI Addict since: May 2006
Default Re: bad fm reception from aftermarket radio ??
IIRC, there is an antenna wire (not the actual antenna) that needs to be hooked up.
For most cars, it's used to power the motor for raising and lowering the antenna, but I think it's used as an amplifier for the antenna on our cars.
Hope that helps.
halfbr3d is offline   Reply With Quote
Old 10-01-2007, 07:56 AM   #3
Car: 05 OBP WRX STi
Fav Mod: Right Foot
IWSTI Addict since: Dec 2006
Yep our cars have a hidden antenna that requires an antenna amp. Make sure you hooked up the antenna amp so it gets power, w/o it your FM reception will be horrible.
atomicfire is offline   Reply With Quote
Old 10-01-2007, 08:09 AM   #4
Car: 06 WRB GOLD STI
Fav Mod: NRA Sticker
IWSTI Addict since: Mar 2006
I have the Kenwood NAVI DDX7017 and have decent reception its not great though, sirius FTW though
Old 10-01-2007, 08:16 AM   #5
IWSTI Addict since: Jun 2007
I agree with the above. I did NOT conenct it when I test ran my 7100 install. Noticed the reception was horrible. I connected the wire and bam, reception. I think it's purple...
boxtwo is online now   Reply With Quote
Old 10-02-2007, 05:53 AM   #6
Car: 06 sti wrb
so there would be 2 wires for the antenna? (antenna and antenna power)
Old 10-02-2007, 06:27 AM   #7
Yes, there is the actual antenna wire (plug style) and the power antenna wire which is actually for the FM amp.
Old 10-02-2007, 07:13 AM   #8
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IWSTI Addict since: Apr 2006
These people are correct. I had the same issue.
Old 10-02-2007, 10:22 AM   #9
Look in the install guide for the radio, it will have a wiring diagram with colors. It will say something like "power antenna" for the wire that needs to be connected for the FM amp. The instructions were a little ambiguous as to what they mean, since we have no power antennas (thinking of the retractable type.)
Check out: Subaru WRX radio harness pin-out
Specifically #14 on the pinout description matrix. For MY07 (at least) it is for the FM amplifier.
Goood luck!
