Old 04-06-2004, 01:23 PM   #1
Car: none
IWSTI Addict since: Mar 2004
Send a message via AIM to Chiznarles
I'm in the process of installing my amps, and after removing my front seats I noticed that there are A/C Vents under our seats, my guess is its for the rear passengers feet.
But this means that if you install amps under ur front seats, there will be A/C blowing on your amps, this is extremely good for cooling amps as they get very hot. Not to mention there is alot of clearance under our seats for a decent sized amp.
Just wanted to let you guys know.
I'll post up pics of my install later. Here are the specs of my system.
Pioneer DEH-740MP Headunit
Panasonic CMD-V9000U DVD Player w/ 7" Flip out screen
Focal 165V Slim components in front
Phoenix Gold Tantrum 600.4 Amp for components
Two JL Audio 10W3
Rockford Fosgate Punch 800a2 Amp for subs
Audiopipe 1/0 Gauge power cables
IA Performance STI Speaker installation kit
IA Performance STI Wire Harness
Second Skin Damplifier for Sound Deadening
Chiznarles is offline   Reply With Quote
Old 04-06-2004, 02:05 PM   #2
Fav Mod: Software Engineer
IWSTI Addict since: Sep 2003
Send a message via AIM to t00h0t
I just purchased the same Tantrum 600.4 amp. Does it fit under the seats? I also have the Tantrum 1200.1 for my sub. That would be great if I could get one under each seat! Please keep us informed!
t00h0t is offline   Reply With Quote
Old 04-06-2004, 02:42 PM   #3
Car: none
Yes, the Tantrum 600.4 will fit under the seat! As long as you don't have the endcaps (which cost extra anyway).
Old 04-06-2004, 05:20 PM   #4
mcR
Car: cars
IWSTI Addict since: Feb 2004
Send a message via AIM to mcR
dont forget about the winter time when u have the heat on...
mcR is offline   Reply With Quote
Old 04-06-2004, 07:01 PM   #5
Car: none
No problem. Just don't set the heater to the foot area when you're using it. Plus I live in So Cal. I don't need to worry about the winter too much.
Old 04-07-2004, 05:09 AM   #6
IWSTI Addict since: Jan 2003
Amps rarely have overheating problems these days unless your are overloading them.
TL-racer/STi-driver is offline   Reply With Quote
Old 04-08-2004, 11:53 AM   #7
Car: Anything fast...Cars
Fav Mod: USAF Network Egineer(2E251)
Send a message via AIM to WFKV Send a message via Yahoo to WFKV
Unless you are running a class D amp you have to worry about heat! If you are running a class AB amp then you need to make sure either you don't turn your gain up that high or don't run it for long periods of time. Also it depends on what type of load you are putting on the amp! If you take a class AB amp and hook up a load of 1 ohm(if stable to 1 Ohm) then you are going to be putting out more heat then if it were a 4 ohm load! I would install my mids & highs amp under the seat but I would put the sub amp in the trunk somewhere! IMO
That is unless your amp has a good fan system or you hook a 12v fan up blowing onto it being under the seats is just doesn't give great air flow!
Does the AC blow through these vents? I thought they only worked for the heat?
Will
WFKV is offline   Reply With Quote
Old 04-10-2004, 10:39 PM   #8
Fav Mod: Mobile Electronics Installer
Default yet another LitchField STi HyBrid
The problem with open a/c vents near an amplifier isn't the air temp as much as the condensation from the air. This isn't a problem with a properly functioning a/c system usually but to be safe I would put some duct tape on those...um ducts.
adamantiumSTi is offline   Reply With Quote
Old 04-12-2004, 09:40 PM   #9
Fav Mod: GT-35R
Default Free Mag for us
i cut those vents, taped them off, and ran wires through the last bit that goes through the metal. worked great for a grommet! i had alot of wires, and it worked great to run them through there.
cnstman is offline   Reply With Quote
Old 04-13-2004, 06:43 AM   #10
Car: 04 WRB STi
Fav Mod: Trailer Hitch
I put my amp under the pax seat also. Vents are bad there. 1) Summer AC the amp will be cold, when you opent he door, the air strikes cold metal and condensation forms. 2) Winter - heat blowing on the amp.
Neither of these are horrible but are less than ideal. I removed the ducts at the next junction and like cnstman said, used the resulting holes in the crossmember to run wires through. Very trick and no heat / AC to the amp.
Don
donmei is offline   Reply With Quote
