Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > I.C.E/Security
Old 05-26-2006, 11:37 AM   #46
Fav Mod: Dom 3r
Whats the sound like? Anyone have some comparrisons so we have a remote idea of what it might sound like? :P
meffie is offline   Reply With Quote
Old 05-26-2006, 12:14 PM   #47
Car: 05 Subaru Sti
Fav Mod: They all work as one (All)
Subscribed, please more info on sound difference. How well do these subs perform???
sti 5501 is offline   Reply With Quote
Old 06-01-2006, 09:50 AM   #48
Car: 05 STI
Fav Mod: None YET
Any issues crossing this over with factory speakers? Would bass blockers or some other in line high-pass filters work well to keep the factory speakers from distorting at higher volumes? Or does this sub still max out at about the same level, just with deeper frequencies?
LoveMySTI is offline   Reply With Quote
Old 06-11-2006, 12:52 PM   #49
Fav Mod: Suspension
Send a message via MSN to Sunfighter
To the OP, thanks for the post and the pictures! I didn't even know this product existed and it seems like a perfect solution for me since I don't want a heavy sub and amp in the trunk and I do want a little bit of bass.
Sunfighter is offline   Reply With Quote
Old 06-13-2006, 12:13 PM   #50
Fav Mod: fix-it tickets
Send a message via AIM to SUBIRU
no i didn't have any issues crossing over with factor speakers. i don't think bass blockers are necessary. the sub has its own power level control so u can dictate that it max out early or late. but its a nice noticable difference with sub as opposed to without.
yw! then this is a very feasible and logical solution for you.
SUBIRU is offline   Reply With Quote
Old 06-13-2006, 01:27 PM   #51
Car: 05 World Rally Blue
Awesome, thanks for the post man. Do you need an amp for this as well?
P.S. I suck with sound stuff, I just like the noise it makes.
STiSpeed is offline   Reply With Quote
Old 06-13-2006, 01:31 PM   #52
Fav Mod: Dom 3r
No you don't, theyre self powered.
Old 06-14-2006, 08:45 PM   #53
Photography Mod
two more questions:
what gauge wire did you use to power/ground it?
what firewall entrance did you use to get the cable from the battery into the cabin?
Old 06-14-2006, 11:02 PM   #54
Originally Posted by Parker
two more questions:
1) i used the one that came with the sub. it was yellow. i'd guess it was a 10/12 gauge.
2) i used the one near the brake pedal since the routing was near the cabin floor. also, the one under the i/c was occupied by my defi wiring.
hope all goes well with the install!
Old 06-22-2006, 03:06 PM   #55
Car: 05 STI
Fav Mod: None YET
Got it for father's day and installed it yesterday. Pretty much what I expected. Not going to win any big bass contests, but adds a nice bottom end inside the car. I am still trying to figure out what to do with the remote. Once I get it adjusted, I probably won't be touching it very much, so I thought I might just leave it under the seat. I saw where one person said they mounted it near the parking brake handle. I would love to attach it to the underside of the center console lid, but I don't feel like drilling holes in it to run the wire.
Old 06-22-2006, 06:31 PM   #56
Car: 06 WRB GOLD STI
Fav Mod: NRA Sticker
looks very clean, bet it sounds good too!
Old 06-22-2006, 06:54 PM   #57
Car: 05 Aspen White STi
Fav Mod: GREEN
Send a message via AIM to SubyFreak05
Subscribed, I am also very intrested in this, I might pick one up. How simple is the install, not the getting power part, but giving it feed from the Head unit? Do you just plug right into the back of the H.U.?
SubyFreak05 is offline   Reply With Quote
Old 06-23-2006, 10:27 AM   #58
Car: 05 STI
Fav Mod: None YET
It does not plug into the head unit. You will have to find a diagram of the factory plug to tap into the speaker wires and the 12v accessory wire. I used wire taps. I ran the fused wire to the battery like the op did, and grounded on a metal surface behind the dash. For me, the hardest part was deciding on the best route for the yellow (power) wire through the dash and engine compartment.
Old 06-26-2006, 04:32 PM   #59
Photography Mod
Ok, ordered mine today. I should be able to install it in a week or so...hopefully its as good as you say it is!!!
Old 06-29-2006, 07:02 PM   #60
Car: 2005 Subaru WRX STi
Send a message via AIM to Mochenmat
Originally Posted by blk rex
Does it tickle your passenger's ass?
Mochenmat is offline   Reply With Quote
