Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > I.C.E/Security
Old 03-25-2006, 10:02 AM   #16
Fav Mod: fix-it tickets
Send a message via AIM to SUBIRU
i got mine from www.techronics.com , @ 140$ new.
SUBIRU is offline   Reply With Quote
Old 03-27-2006, 04:30 PM   #17
Car: 05 WRX STi
I just ordered one from techronics.com as well. Great install, now I need to find some velcro since I also don't want to drill holes in the floor either.
TRex is offline   Reply With Quote
Old 03-27-2006, 06:02 PM   #18
cool, the install shouldn't be bad, are you gonna put it under the seat as well?
Old 03-28-2006, 04:24 AM   #19
Car: The Vroom-mobile
Fav Mod: JDM Gears
Velcro can be found at your local hardware or grocery store.
Old 03-28-2006, 09:53 AM   #20
Car: 05 WRX STi
I am mounting it under the seat as well, along with a 4X power amp. Can't wait.
Old 03-28-2006, 10:37 AM   #21
oh come to think of it.. advice since you're going to use velcro. naturally you know to use the spikey side of velcro, but even tho i had the velcro with the sticky back, i had to use 3M heavy duty exterior mounting tape to secure the velcro strips to the sub.
Old 03-28-2006, 07:13 PM   #22
Car: 05 WRX STi
Thanks for the tip on the tape!
Old 04-01-2006, 11:27 AM   #23
Fav Mod: RCE
Send a message via AIM to ELD4AU6
did you have to run any wires out to the battery, also does this have rca plugs , im thinking about buying this to go with my new radio since i cant use my stock sub any more
ELD4AU6 is offline   Reply With Quote
Old 04-01-2006, 12:26 PM   #24
you just have to run the power cable to the battery. yes it does have rca plugs. good luck!
Old 04-01-2006, 02:49 PM   #25
Fav Mod: RCE
good i think i will go with this rout since my stocker is going bye bye
Old 04-01-2006, 08:06 PM   #26
Car: 05 WRX STi
Got mine installed last night, just the right amout of punch for me. Thanks for the tip on this great little (big sound) sub.
Old 04-01-2006, 08:22 PM   #27
Car: 06 SGM STi
Fav Mod: V1
Did you have the OEM sub previously? If so, how does it compare.
Edward is offline   Reply With Quote
Old 04-06-2006, 04:15 PM   #28
can anyone answer this? i'm interested.
Old 04-06-2006, 04:30 PM   #29
RSV2/BF2142 Player
Fav Mod: Fixing Subie Rattles :)
Send a message via AIM to SiCkSTi04
would there be any problem's with removing the front pass seat and airbag light? i know some cars if the seat was removed and put back that the airbag light would come on and have to reset using a relay or paperclip
SiCkSTi04 is offline   Reply With Quote
Old 04-09-2006, 09:08 AM   #30
i don't know the answer to the stock sub and airbag questions. so bump for answers!
