Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > I.C.E/Security
Old 01-10-2006, 01:30 PM   #1
Fav Mod: fix-it tickets
Send a message via AIM to SUBIRU
Default Trunk Release module on 05 STi question
The Legacy alarm remotes have a trunk release button on them. I know that the remotes can be programmed to work with an 05 sti alarm unit. my question is, does the alarm unit on the STi support the additional trunk release button on the remote?
i did a search on wiring a trunk release kit on factory alarms but the only solution i found was to wire the second unlock press that unlock all doors to unlock the trunk instead. thats not the route i'd like to take.
as i mentioned, i have an 05 STi with upgraded factory alarm. just wondering if the alarm brain itself would be able to utilize the trunk release button from another subaru alarm remote.
SUBIRU is offline   Reply With Quote
Old 01-11-2006, 05:26 AM   #2
Beneath the clothes, we find a man... and beneath the man, we find his... nucleus.
Fav Mod: Underglows
^^ I don't believe so. You could get an aftermarket alarm and have a trunk release installed (I did this on my previous alarm) but there is no mechanism installed on our cars that would allow for automatic trunk open.
Old 01-11-2006, 07:10 AM   #3
hey SVT, i'm aware that our cars don't have the trunk release mechanism, but if i bought one (a trunk release kit - comes with solenoid, wiring, relay), can i attach it to the existing factory alarm brain?
Old 01-11-2006, 02:10 PM   #4
Fav Mod: Underglows
^^ Oooh, that I don't know.
Old 06-20-2006, 09:26 PM   #5
Fav Mod: coilovers & www.hpdedriver.com
Send a message via AIM to SubyFi
Hey dug this post up with a idea I came up with.
Do this mod to have the unlock button to unlock all four doors on one press.
http://www.scoobymods.com/forums/showthread.php?t=3077
Then this frees up the RED with GREEN stripe wire (used to be the unlock all doors) to trigger a remote trunk setup (relay, solenoid). So when you push the UNLOCK button on the transmitter 2 times within 5 seconds, the trunk will open.
Okay, who wants to do this first?! Please post a write up
SubyFi is offline   Reply With Quote
Old 06-21-2006, 07:45 AM   #6
i heard of that, but you have to get rid of the safety lever on the inside of the trunk.
Old 06-21-2006, 08:38 AM   #7
I don't understand why the emergency escape handle has to be removed. The trunk opening solenoid pulls a cable to release the latch. You can drill a new hole in the latch for the solenoid cable.
Old 06-21-2006, 03:49 PM   #8
Moderator
Car: 05 Ram 3500 CTD
Fav Mod: Majin
IF SOMEONE DOES THIS I WILL FOLLOW SUIT. If no one does this in the next 2 months, it will be done by me. I loved that feature on my last car.
subscribed...
Old 06-22-2006, 07:59 AM   #9
Fav Mod: Nintendo Decal
Anybody priced out trunk solenoids or know how much will run me? Any tips on manufacturers as well?
unrequited is offline   Reply With Quote
Old 06-22-2006, 11:31 AM   #10
I'm doing that Scoobymod thing this weekend. I hate staged door locks.
klaymon is offline   Reply With Quote
Old 06-22-2006, 04:50 PM   #11
Moderator
Fav Mod: Majin
keep us filled in on that, I am interested to know how easy it goes. This is something that GREATLY interests me.
Old 06-24-2006, 12:20 PM   #12
Staged door lock bypass mod complete.
At first, I tried jumping the two wires together just to make sure it was going to work before I went to the trouble, and it blew the door lock fuse. So, I replaced the fuse, bit the bullet and cut the red with green stripe wire and used a vampire tap to attach the harness side of the wire (not the little piece left with the plug) to the red one right beside it. Works like a champ. All doors unlock with one button push.
So with that said, if you can get a solenoid attached to the release in the trunk, you could do this mod and use the wire left coming out of the plug (red with green stripe) to trigger the trunk solenoid with the second button push.
Here's a crude MS Paint diagram of what I'm really saying:
Old 06-24-2006, 12:26 PM   #13
Car: Thats faster than yo
Fav Mod: 282 whp 271 wtrq
Send a message via AIM to ThisizBrian
subiru, at any alarm installation place they can install the selenoid to pop your trunk via the alarm. i think it just needs to be programmed to one of the buttons.
ThisizBrian is offline   Reply With Quote
