Old 08-19-2008, 01:13 PM   #16
Fav Mod: Speeeeed!
IWSTI Addict since: Apr 2007
Default Re: DashDAQ Subaru STi Theme v 1.0
Originally Posted by dchou View Post
Hey Shahrum,
I replied to your PM. You need to PM me your email so I can send you the pics you want.
Dave
Thanks Dave, check your PM's.
Originally Posted by valdar View Post
Same here. I'm wondering about the cable though, in the pictures I can't see one, but maybe it's just that well hidden...
Do you just need an OBD cable or is there also a power cable?
I keep thinking of ways you mount this in the clock pod somehow...maybe a flip down thing.
It's really easy if you've ever done any stereo installation or removed interior panels of your WRX/STi to get the clean install that I opted for. There is only a single cable, the OBDII cable. OBDII provides power as well as the signal for all of the values that the DashDAQ gauges display. The way I routed it was that I removed the A pillar cover and passed the OBDII cable down through the dash to underneath the steering column. From there, instead of plugging the cable into the built in recepticle, I removed the OBDII port and tucked it back further below the dash using cable ties. This way I don't have to worry about my legs kicking or getting in the way of the connector.
Since those photos were taken, I actually relocated my DashDAQ using a ProClipUSA.com center vent mount and routing the OBDII cable through the center console A/C vent and below to the port. It's much cleaner and easier to use. New photos will be posted soon!
Shahrum is offline   Reply With Quote
Old 08-19-2008, 01:15 PM   #17
Fav Mod: Speeeeed!
The best view of the cable is in this photo:
You can see that it basically goes behind the A pillar cover and is routed through a hole that already exists in the top of the dashboard (concealed by the A pillar cover). That hole channels directly down to the bottom of the steering column area when you connect it to your OBDII connector. At that point you can choose to do what I did and basically unclip the car's OBDII connector from it's stock location and relocate it further back & up so that the cable doesn't get in the way of your legs.
Old 08-19-2008, 04:27 PM   #18
Fav Mod: Cobb AccessPort Stage 1
IWSTI Addict since: Feb 2008
Send a message via AIM to hairlesswookiee
can you take some good pics of all this??? i love the display and will probably get one in a couple of months if this can be installed without problems of it hitting my legs.
hairlesswookiee is offline   Reply With Quote
Old 08-19-2008, 04:32 PM   #19
Fav Mod: Speeeeed!
Definitely, I'll be sure to show photos of the wiring as well when I update the photos. I'd expect those to hit here over the weekend at the earliest so that I can clean up the inside a bit too
Old 08-19-2008, 04:37 PM   #20
thanks man!!!
Old 08-19-2008, 05:02 PM   #21
Car: silver 05 rex STi
Fav Mod: T3/T4 turbo for my ranger
IWSTI Addict since: Dec 2006
Send a message via AIM to turboranger Send a message via Yahoo to turboranger
ohhhhh looks interesting!!!
turboranger is offline   Reply With Quote
Old 08-25-2008, 05:08 PM   #22
Fav Mod: Speeeeed!
Hey all, I have posted a new thread with a bunch of new photos:
http://www.iwsti.com/forums/i-c-e-se...cs-8-25-a.html
Thanks!
