Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > I.C.E/Security
Old 07-22-2008, 05:46 AM   #1
Car: 05 STi Black on Gold
Fav Mod: Stage 2
Send a message via AIM to boostin05blacksti
Default JL 10w3v3-2 Vs. JL 10w7-3
Hey everyone, I am looking into these two subs, and what i am seeing is that you get what you pay for. I know that i want a 10' sub and I know that I want it to be a JL. The w3v3 info is 2 ohm,mineral-filled polypropylene cone with nitrile-butylene rubber surround, 25-250 Hz, 100-500 watts RMS power range..and the price is 240. The W7 info is 3 ohm,
polypropylene W-Cone with polyester foam surround, 20-250 Hz frequency response, 250-750 watts RMS power range and the price is 640. If anyone has these please feel free to chime in. I am going to get either one or the other. As far as an amp I was thinking of the alpine mpr-m500 which is a mono amp 500 wattr rms x 1 at 2 ohms. I know this amp is ideal for the w3...but what amp would best utilize the power of the w7..? I am very new to car audio so go easy one me. Just looking for some help. Also where is a good place to buy from. I was on crutchfield but there prices seem very high.
Thanks, Steven
boostin05blacksti is offline   Reply With Quote
Old 07-22-2008, 11:51 AM   #2
Default Re: JL 10w3v3-2 Vs. JL 10w7-3
I have had 10w3's and they sound great, you can never really run the rms power they recommend. I had my 10w3's up to 200 watts rms and they were at there limit. As far as w7's thats a whole new ball park. In order to run w7's you will need a good amp. I recommend jl audio's amps. Between the subs and mids highs you will be using alot of power. This will require a better battery,multiple caps and an upgraded alternator. I would recommend 3 10w3's and it will sound great in the car, if you want to advertise 2 or 3 12w3's. As for great deals on jlaudio and high end car audio here are 2 links with great prices;
Techronics.com - Online Electronics Store -
Onlinecarstereo.Com - Wholesale Car Audio/Stereo Deals At Bargain Prices
SubySteve is offline   Reply With Quote
Old 07-22-2008, 01:11 PM   #3
Car: 06 CGM STI
Fav Mod: Apex'i GT Spec
Send a message via AIM to subiesteye
if you want a 10w7 get atleast a 800watt amp to power that thing..it will give a lot of power, but u want the amp to support it as well..you wont have to worry bout maxing out on the sub..it can def take the power
subiesteye is offline   Reply With Quote
Old 07-22-2008, 01:16 PM   #4
Fav Mod: Stage 2
thank you sir.
Old 07-22-2008, 06:33 PM   #5
The w7's will require a very stable current. If the amp you use cannot provide that it will fry it. Remeber some amps tell you there rms power but thats @14.4 volts. You what an amp that can produce that power @ 12.5 volts. A good rule of thumb is to see what size fuses it uses. 10 amps=100 watts, so if it has 2 30amp fuses its good for 600watts. Some of the newer amps are more efficent so this rule will not apply completely.
Old 07-22-2008, 06:37 PM   #6
Car: 2005 Aspen White STi
Fav Mod: T-Tops
10w6v2.
SLY STi is offline   Reply With Quote
Old 07-25-2008, 08:17 AM   #7
Car: 04' STi (JBP)
Fav Mod: Cobb Stage 2
Send a message via Yahoo to couchflambeau
Originally Posted by SLY STi View Post
10w6v2.
x2....
I have two myself... good compromise (performance vs. price)...
couchflambeau is offline   Reply With Quote
