Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > I.C.E/Security
View Poll Results: Which would you get for more bass/clarity
Infinity 8 80.00%
Pioneer 2 20.00%
Voters: 10. You may not vote on this poll
Old 07-17-2008, 07:22 PM   #1
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
Default Infinity vs Pioneer
Infinity Reference 4022i or Pioneer A door speakers, which to get? I want more bass without having to run an amp. $200 budget
B4RSTiwsnc is offline   Reply With Quote
Old 07-17-2008, 07:29 PM   #2
Car: Grey 07 Sti Ltd
Fav Mod: SPT Intake
Default Re: Infinity vs Pioneer
I personally went with Polk audio db6500. They sound great w/o an additional amp. Have you gotten rid of your OEM speakers?
LTD472 is offline   Reply With Quote
Old 07-17-2008, 07:33 PM   #3
^ still have them, but I have an Alpine reciever
Old 07-17-2008, 08:07 PM   #4
Fav Mod: SPT Intake
Oh ok. good. I used mine as spacers. http://i349.photobucket.com/albums/q...2/DSC03573.jpg
http://i349.photobucket.com/albums/q...2/DSC03575.jpg
http://i349.photobucket.com/albums/q...2/DSC03574.jpg
http://i349.photobucket.com/albums/q...2/DSC03578.jpg
http://i349.photobucket.com/albums/q...2/DSC03579.jpg
http://i349.photobucket.com/albums/q...2/DSC03577.jpg
I had to cut where I circled b/c it wouldn't allow the trim panel to clip back onto the door. No big deal, easy to do with a razor blade.
Old 07-17-2008, 08:14 PM   #5
Fav Mod: SPT Intake
I forgot to add that you have to cut out the center of the OE speaker so you can place the new 1 on top. I used a dremel. With out the OE speaker used as a spacer, the sound is terrible. It made a huge difference with them. I don't know if using an A/M spacer would sound just as good. I don't think they would come close since these fit perfectly of course.
Old 07-18-2008, 12:46 AM   #6
Young and restless
Car: 2005 Aspen White STI
Fav Mod: Torque
Send a message via AIM to MikeO Send a message via MSN to MikeO
Between the two, DEFINITELY go with the pioneer A series. I just recommended them in another thread and they are by far the more bass heavy speaker over the infinity. Infinity's speakers hold their strengths in the quality of their high's and mid tones.
MikeO is offline   Reply With Quote
Old 07-18-2008, 07:46 AM   #7
Newegg.com - Pioneer A-Series 4.0" 3-Way Speaker with 150W Max. Power Model TS-A1072R
I was reading that article and one guy said that the bass was not impressive at all though
Old 07-18-2008, 09:05 AM   #8
Fav Mod: Me.....
I'm a pioneer fan but for speakers, Infinity has better quality of sound in IMO.
twigg107 is online now   Reply With Quote
Old 07-18-2008, 09:11 AM   #9
Car: 08 Gray STi
To Infinity and beyond!
Old 07-19-2008, 05:00 AM   #10
Car: 04' STi (JBP)
Fav Mod: Cobb Stage 2
Send a message via Yahoo to couchflambeau
LOL... 3 way coax...
and of course bass is gonna suck on a 4".... simple physics. Cone area x excursion = bass (ok oversimplified but you get the idea)
Low frequency reproduction is similar to that old muscle car saying...
"there's no replacement for displacement"
Depending on brand, a 4" speaker is going to be worthless under 100-150Hz... I'd strongly recommend capping them off (electronically or with inline capacitors) at around 120 Hz or so since they'll just fart at lower frequencies.
If you're adding 4" speakers to the rear for low frequency reinforcement, you're going to be disappointed. Good amplified front speakers, underseat subs, or a trunk mounted sub are the route you wanna follow.
Consider the kenwood underseat sub or the infinity basslink.... either for under $250 and will fit your requirement a lot better than 4" speakers in the rear.
couchflambeau is offline   Reply With Quote
Old 07-19-2008, 05:53 AM   #11
Fav Mod: The Newest One!
Im an infinity guy when it comes to speakers. They have never failed me.
Old 07-19-2008, 06:39 AM   #12
Car: 06 CGM STI
Fav Mod: armorall
Send a message via AIM to subiesteye
alpine type x
subiesteye is offline   Reply With Quote
Old 07-19-2008, 07:25 AM   #13
I am leaning toward the infinity myself, I am not looking for earth shattering bass in a sub, just something noticeably better than stock
Old 07-19-2008, 07:40 AM   #14
Car: 04' STi (JBP)
Common misconception....
You don't add subs for "ear shattering bass"...
But thanks to all of the low grade morons running around with 15"s and wattage ratings in the k-watts the conclusion is that subs are for LOUD.
Not so.
What I am telling you is...
The original post inquired about adding 4" speakers in the hopes of reinforcing a little bit of low end into the system. If that is the end result you want then adding a couple of speakers that at best will reinforce the midrange response of your system is almost certainly going to fail to fulfill those goals.
I'm not trying to be an @-hole, but based on what was mentioned, you're throwing your money away on either of those choices.
If you really want to help low freqency response to the system, I would at the very least modify the rear doors to take a 5 1/4" or a 6" speaker if a dedicated sub is out of the question.
Sorry if that's not the answer you want to hear, but I've worked in the audio install industry for years, and now as a hobby take it to a much higher level than your run of the mill car audiophile. I'd much rather see you get some results from your investment rather than just throw a couple of speakers in the stock holes and come away unhappy.
Old 07-19-2008, 12:39 PM   #15
will the Infinity 6022i fit in my front doors without custom fitting?
