Go Back   IWSTI.com: Subaru STI Forums > STi Technical Discussion > I.C.E/Security
Old 06-26-2008, 02:52 PM   #1
Default Cd's stuck in 6 disc changer! 2005 sti stock
I went to eject one of my cd's and mid-eject I turned my car off. Well in the past I thought it always just continued to through the eject sequence but it just stopped. When I turned the car back on, the cd player function would not respond and after a few seconds it switched to the radio function. switching back to cd function did nothing. turning the ignition off and on does nothing.
I have 6 cds stuck in there and one belongs to the library!
Any tips? Not under warranty. No money.
Thanks,
Jeff
Es-Ti-Aye is offline   Reply With Quote
Old 06-26-2008, 03:03 PM   #2
Car: 08 WRB STi
Fav Mod: ditching the cats
Default Re: Cd's stuck in 6 disc changer! 2005 sti stock
In dash CD changers notoriously jam up. You can pull the radio out and open up the CD player. It's not that hard. I did it when I installed the Jazzy aux input adapter on my 05. Just be very careful when your trying to unjam the CD's as to not bend anything. You can do permanent damage that way.
Old 06-26-2008, 03:11 PM   #3
Are you saying there is an aux input adapter that will work with the stock stereo?!
Do you know where the wiring harness (power) source for the stereo is?
Old 06-26-2008, 07:16 PM   #4
Car: 08 WRB STi
Yes. It's made by a company called jazzy engineering. You have to crack open the radio to put it in, but since you need to get your discs out then you might as well throw this in.
In the back of the radio.
