Old 06-17-2008, 05:15 PM   #1
Car: OBP 07 STI
IWSTI Addict since: Aug 2007
Default Voltage Gauge - Clock mod
After installing My new Nav system, I realized I had two clocks. The Eclipse's clock works off the Nav so you never have to set it. Plus after installing my Optima battery and new amp, I wanted a Voltage gauge. So here was my fix.
Used a stinger Digital voltage gauge. I soldered the stinger gauge right to the circuit board after removing the clock gauge. Had to do some trimming on the surrounding plastic to make it fit. Also covered the Stinger Logo with some black electrical tape, 3 layers. I have to adjust the Voltage still, its reading real high. I used a voltage meter with the car on it should read 14.2-14.4.
Fairly easy mod, and looks better than the green clock...
VantageSTI is offline   Reply With Quote
Old 06-17-2008, 08:27 PM   #2
Car: Silver 05 STI
Fav Mod: Wingless
IWSTI Addict since: Feb 2008
Default Re: Voltage Gauge - Clock mod
Very nice, I like. I have my remote V1 display there, but i suppose i could slide it over to make room for that voltage gauge.
Keeter17 is offline   Reply With Quote
Old 06-17-2008, 09:01 PM   #3
Car: OBP 07 STI
ya, thats a good idea. have any pics?
Old 06-17-2008, 09:05 PM   #4
Car: Silver 05 STI
Fav Mod: Wingless
I will take some later. Im at work currently but when i get off i will try and post some. I have never posted pics before so we shal see.
Old 06-17-2008, 09:08 PM   #5
Car: Silver 05 STI
Fav Mod: Wingless
I dont know about your eclipse unit, but my kenwood nav gets great reception with the antenna just under where the clock was. Although i dont remember how i attatched it, it is not visible.
Old 06-18-2008, 12:30 AM   #6
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
The ecplise gps antenna will work under the clock to. with the stock clock pod. Once i added triple gauge pod it didnt work anymore
Old 06-18-2008, 06:22 AM   #7
approved this message.
Fav Mod: correct grammar
IWSTI Addict since: Jun 2006
FWIW, I have mine under a triple gauge pod and it works fine (Pioneer GPS). I'm lucky enough to have a volt meter in the Pioneer vehicle telemetry.
Old 06-18-2008, 06:24 PM   #8
Car: OBP 07 STI
Ya, I think I'am going to mount the antenna under the pod, looks alot cleaner that way.
Old 06-20-2008, 09:25 AM   #9
Fav Mod: Me.....
I'd rather have a afr gauge there instead.
