Old 05-21-2008, 10:33 PM   #1
Car: BLACK 07 STI
Fav Mod: painted headlights
IWSTI Addict since: Feb 2008
Default what is going on with my door locks? WTF
soooo here is a very big problem i got
so i was installing one of the superbrightleds part# 74 the mini led that goes in the steering column for the key ring thats green.... well i got a nice red one and come to find out right when i put it in well it didnt work. so i looked at it and bent the two thin metal contact sticks(best described) and put it back in well right when i did that my driver door locked and i said quote omfg well here is what resulted
my driver door will not unlock via keyless entry or pushing the door unlock switch on driver or passenger side
when i go to manually push the switch by the door handle to unlock the door the switch says FU and immediately locks itself back like super fast
my other doors do not respond to the keyless entry or door lock/unlock switches
the indicating lights still flash and the horn still honks when armed even those the doors are not unlocking or locking
this is what i have tried
battery disconect
switching back to the oem bulb
and just about every single thing the manual says about the alarm system
mind you i really dont wanna do to the dealer
so thats about it i wish you all of luck cuz im stumpped
-andrew
STI-DMNHNTR is offline   Reply With Quote
Old 05-22-2008, 12:06 AM   #2
Car: 06 Subaru WRX STi
IWSTI Addict since: May 2006
Default Re: what is going on with my door locks? WTF
Have you checked all the fuses behind the coin door? can you start the car?
Old 05-22-2008, 08:34 AM   #3
Car: BLACK 07 STI
car starts runs good no changes
actually havent checked the fuses
im working right now but im thinking that may be a good idea
pretty lame that a little led will blow the door lock fuse
i dunno well see
Old 05-22-2008, 01:15 PM   #4
Fav Mod: Protune
IWSTI Addict since: Dec 2007
sounds strange. only thing i can think of would be to double check the area you were into earlier and make sure all the wires are firmly connected, not touching ground, check wire shielding, etc.
good luck
demonrage is offline   Reply With Quote
Old 05-22-2008, 02:08 PM   #5
Car: BLACK 07 STI
yeah well i will def check the fuses and all the wires
im actually going to take it to my tuner today haha but he says hes not that good with wiring he hates it lol i post up our finding but yeah
thanks guys its good thing yimisport is bada$$ like that
