Old 10-01-2007, 04:19 PM   #1
Muller Chevrolet
Fav Mod: fp green
Default horn with aftermarket steering wheel
i have a personal steering wheel with nrg quick release and hub..
how the hell do i get the horn to work again?
Old 10-01-2007, 04:32 PM   #2
Car: 2008 STi
Send a message via AIM to its reneeee
Default Re: horn with aftermarket steering wheel
hey billy, heres the diy i followed when chris(trnkmnky) and i hooked up my wheel. i didn't have any issues after, the horn stayed connected 24/7
http://forums.nasioc.com/forums/show...&highlight=nrg
its super easy but the guy doesn't explain exactly where the horn wire is. you need to follow the yellow airbag wire and once you are deep under the dash you'll find the green/red horn wire. i know you'll figure out it
which personal wheel did you get ??
its reneeee is offline   Reply With Quote
Old 10-02-2007, 07:48 AM   #3
Muller Chevrolet
Fav Mod: fp green
hey renee i got the same as you, i was going to pm you but i forgot your username on here.
i followed that writeup yesterday but i'm confused with the black and yellow wires in the nrg hub and quick release.
the personal center cap only has one hookup point also.
i wired it up like the writeup and tested the wire and the horn was staying on? like i touched the green/red wire to the hub and it would just keep going off without pushing the button.
my wire wasn't so deep cause i just ripped the connector right off the old plastic hub and snipped it apart.
Old 10-04-2007, 05:10 PM   #4
Car: 2008 STi
hey man sorry for the delay on the reply, yea iirc i hooked the black wire to the horn and tucked the yellow one. i had the same issue with the horn staying on at first. i had to switch the wires around until everything was right.
Old 10-04-2007, 09:51 PM   #5
Muller Chevrolet
Fav Mod: fp green
that's what i thought, i'll try it again!
