Old 10-03-2007, 03:19 PM   #16
Default Re: My AP install
Originally Posted by wpwm020 View Post
yep im stage 2 right now and i'm hitting 20.4 psi and in a week or so i'll get protuned.
hopefully you have a boost gauge. you cant rely on the ap for numbers above 18.4. 18.4 is the max it will show on the screen. (assuming they havent fixed this issue since june when i stopped using the ap and got defi's installed)....
esqdgg is offline   Reply With Quote
Old 10-03-2007, 03:56 PM   #17
Car: 05 OBP STI
the stock boost gauge it's doing its job so far
wpwm020 is offline   Reply With Quote
Old 10-03-2007, 04:36 PM   #18
sure the stock one should work just fine. The ap will only read up to 18.4
Old 10-04-2007, 06:15 AM   #19
Car: 2007 SPW STi
Fav Mod: TBE
Send a message via AIM to Deadtoday
Thats neat, good job. If it weren't for the gauges not being so accurate in real time I would definitely do the same.
Deadtoday is offline   Reply With Quote
Old 10-04-2007, 06:16 AM   #20
Car: 2007 SPW STi
Fav Mod: TBE
WHAT?! The A/P only reads up to 18.4??
Old 10-04-2007, 06:18 AM   #21
Car: 06 WRB GOLD STI
Fav Mod: DDX7017
yes, right now AP can only read to 18.4 from the ECU, this is not a flaw from cobb, its something in the ECU
