Old 09-25-2007, 12:52 PM   #1
Car: 05 STI
Fav Mod: RED
Default roof vane installation?
does anybody have instructions or template for the install.......?
stipr22 is offline   Reply With Quote
Old 11-01-2007, 12:17 PM   #2
Default Re: roof vane installation?
Bump!
chanders is offline   Reply With Quote
Old 03-03-2008, 07:33 PM   #3
Car: OBP 05 STi
Fav Mod: Rocket Rally Pro-Tune!
bump again please
OBP 05 STi is offline   Reply With Quote
Old 03-21-2008, 02:50 AM   #4
Car: 2007 wrx
Send a message via Yahoo to wesley1202
what roof vane do you have ?
wesley1202 is offline   Reply With Quote
Old 04-06-2008, 08:39 AM   #5
Car: 05 OBP STi
Fav Mod: Girls
Anyone have info on this? I am looking to put a roof vane on an 05 STi
Aurelius311 is offline   Reply With Quote
Old 04-08-2008, 06:05 PM   #6
Fav Mod: Whiteline sways, ohlins coils, cusco motor mounts
Do you already have the vane? Do you have a buddy with an 06-07 car? The base of the vane mounts should be contoured to fit on the c-pillar/roof in a certain way, you can eyeball it. Or if you have a buddy with an 06-7 car you can measure it. Or better yet see if he'll remove the vane for you so you can make templates out of some paper for the holes. That would be the most accurate way.
neal0124 is offline   Reply With Quote
Old 04-13-2008, 12:06 AM   #7
Car: Silver 05 STi
Fav Mod: Works BOV
Send a message via AIM to GetFamiliar82
wanna do the same on my 05' any suggestions??
will the 06' stock vein fit on the 05'??
GetFamiliar82 is offline   Reply With Quote
Old 04-13-2008, 04:39 AM   #8
Scoobie Dooby Doo
Car: Is freaking fast!!!
Fav Mod: Going turbo
I don't have a template, but I did go down to the local dealer when I did mine and measured the distance from the top of the back window to the front of the vane mounting brackets and it turn out to be about an inch. If you buy yours from a dealer you can use the mounting brackets as a template. just tape them into place. here is how mine turned out. Mine has been on for about a year and a half with not problems at all.
scoobster is offline   Reply With Quote
Old 04-13-2008, 06:09 AM   #9
Car: Silver 05 STi
Fav Mod: Works BOV
you are the man dude. saved me a lot of headache. thanks. this is definitely my next mod.
Old 04-17-2008, 10:13 PM   #10
Car: 07 STi Ltd
Fav Mod: ECU Tuning that I haven't done yet...
I don't know who's telling lies here.
I bought me one for my 07 Ltd along with car purchase itself. After it came to the dealership, they called to come to have it installed. When I arrived they started putting the vane on, and 15 minutes later dealership manager called and showed that on cars with roof vane there's supposed to be a bolt sticking out of the body, welded to it, that you're suppose to bolt your vane to, and that they could fabricate something but he wouldn't guarantee it's not gonna bend something.
So after all I ended up with credit for the vane...
WaniuszY is offline   Reply With Quote
Old 04-17-2008, 11:26 PM   #11
Car: CGM 05
Fav Mod: stock BPV ;) happy gabe?
Send a message via AIM to 1loudsti
i would like to hear the answer to this.....dealer told me the same thing
1loudsti is offline   Reply With Quote
Old 04-18-2008, 12:08 PM   #12
nulla poena sine lege
Car: '06 Works GP
There are industrial strength adhesives you can use instead. That is how some Mini rear spoilers are mounted. Here is a PDF complete with BMW adhesive part numbers. If it will hold the JCW spoiler, it will hold that little roof vane Just be sure to measure correctly as you will be sanding the paint.
QuickSilverSTi is offline   Reply With Quote
Old 04-18-2008, 02:06 PM   #13
Car: 07 STi Ltd
I understand the adhesives and everything, but what about down/upforce generated by the vane that you try to dissipate over thin metal sheet.
On OEM mounting the studs are welded to reinforcing plates underneath and they provide support not the surface metal sheet.
Think about it.
They didn't give up easily, but told me they could fabricate something, but wouldn't warranty it.
Old 04-18-2008, 02:50 PM   #14
Car: '06 Works GP
I've thought about it. What do you think the JCW spoiler is attached to? Sheet metal. That little roof vane isn't going to rip the sheet metal off or bend it...it's not an F1 wing nor nearly the size/weight of the John Cooper Works wing. The adhesives listed in that PDF are strong.
Old 04-18-2008, 08:45 PM   #15
Car: 07 STi Ltd
Well, You do whatever you want. I just know that I had a rattle in the back of my car and to check if it's not a strut I pushed on rear quarter panel, and it left a litlle dent that pissed me off so bad...
And it also depends how fast you drive. If you take your car to the track and be running at like 150MPH, I think it will be quite a bit of force. I heard somewhere that STi wing is generating 80lbs of downforce at 85MPH. Think about it.
To risk or not to risk, that is the question.
