Old 09-25-2007, 12:48 PM   #1
Default Where to feed amp wire threw firewall?
What hole did you guys go threw to run a amp wire to the back of your car?
woad-3 is offline   Reply With Quote
Old 09-25-2007, 12:54 PM   #2
abracious
Fav Mod: Track time
Default Re: Where to feed amp wire threw firewall?
thrOUGH
Old 09-25-2007, 01:02 PM   #3
Fav Mod: Do Luck CF
I threaded my wiring for my gauge senders and my stereo THROUGH a hole in the firewall close to the brake and clutch pedal. There is a rubber grommet on the engine side and a perforate circle of insulation on the cabin side. Just look below the brake master cylinder and you'll see it.
Old 09-25-2007, 01:16 PM   #4
dex
Car: 07 CGM STi
Fav Mod: Stage 2
Send a message via AIM to dex
I drilled a hole in the middle of my seat
dex is offline   Reply With Quote
Old 09-25-2007, 01:30 PM   #5
abracious
Fav Mod: Track time
through it?
Old 09-25-2007, 01:32 PM   #6
Fav Mod: when it's not blown up
The grommet up underneath the brake booster would probably be ideal. There's another one behind the brake pedal but when using that one it's easy to get the wires tangled in the pedals.
jays05 is online now   Reply With Quote
Old 09-25-2007, 02:36 PM   #7
thanks found it. Sorry nerds i spelled a word wrong.
Old 09-25-2007, 03:21 PM   #8
abracious
Fav Mod: Track time
you're welcome.
however, you used the wrong word, but spelled it correctly
Old 09-25-2007, 03:31 PM   #9
Car: Pearl White 07 STi
Fav Mod: Left foot, Right hand, then my right foot!
I melted a hole through the rubber gromit and ran the wire. Works well, and keeps out the moisture.
GoLawrence is offline   Reply With Quote
