Old 10-05-2007, 11:49 AM   #16
Car: 05 Subaru WRX STi
Fav Mod: Bilstein PSS9 Coilvers
Send a message via AIM to IUSTi
Default Re: Install Guide: STi Group-N Engine Mounts
yea, wish i had access to a lift...
IUSTi is online now   Reply With Quote
Old 10-05-2007, 12:21 PM   #17
Car: 08 STi, SSM
Originally Posted by RAPTR View Post
How thick do you think the wood should be?
use a piece of 2x4
Old 10-05-2007, 01:44 PM   #18
Car: 2008 Fitrari Red
Fav Mod: Getting 40mpg
Originally Posted by Good2Go View Post
Don't you need to remove the pitch stop to do this??
You only need to remove the firewall bolt, which can be easily accessed. Also, if using a stock airbox, I'd suggest removing the inlet hose attached to it. Also, keep an eye on the lower radiator hose during jacking!
Stee is offline   Reply With Quote
Old 10-05-2007, 01:51 PM   #19
Fav Mod: Tank the Terrier!
Send a message via MSN to RAPTR
Not the turbo inlet hose but the hose in between the airbox and the turbo inlet, correct?
RAPTR is online now   Reply With Quote
Old 10-05-2007, 01:53 PM   #20
Car: 08 STi, SSM
you could just pop the top part of your filter box off if. The bottom is anchored to the fender well, the top can float if you undo the clips. Be careful with your coolant hoses, don't jack the engine too high.
Old 10-05-2007, 01:56 PM   #21
What would you say the max height would be allowed to jack up without stretching those radiator hoses out of place? I'm,sorry I'm being super anal about all this.
Old 10-05-2007, 04:47 PM   #22
Muller Chevrolet
Fav Mod: a new 08 STi
the radiator is connected to the engine...when you jack the motor up it's pretty much everything.
VSGTS14 is online now   Reply With Quote
Old 10-25-2007, 01:16 PM   #23
Car: Zero/Sports TA STi
Trader Rating: (16)
Send a message via AIM to edoperformance
Originally Posted by flytojungho View Post
i heard people not removing the pitch mount for this but i dunno for sure
You can remove the pitch stop, and sometimes it makes it easier. but it's not a required thing to do. I find that leaving it attacked helps keep the motor/trans assembly from moving backwards when lifting.
edoperformance is offline   Reply With Quote
Old 03-15-2008, 07:02 PM   #24
I finally did this myself. I used a cherry picker instead of the jack on oil pan. It was really easy because i already had the exhaust manifold off which made the bolts accessible without struggle. Thanks again for the write up!
Old 03-16-2008, 05:58 PM   #25
Iron Fisted
Fav Mod: Sparco seat
Can you PM me the price for this installed at your shop, along with a tranny mount?
I'm just a little nervous futzing around under an engine...
Old 03-30-2008, 05:54 PM   #26
Car: 2006 STi
Fav Mod: Any Turbo Upgrade :)
Send a message via AIM to STI.KID
Anyone else have any pointers for the rear bolt on the passenger side lower mount? I don't want to have to remove the exhaust manifold, but I am thinking that's the only way to get a handle on that bolt. I even bought a pitched 14mm racheting open-end to no avail.
STI.KID is offline   Reply With Quote
Old 03-30-2008, 06:02 PM   #27
Car: 07 STI
Fav Mod: Zzyzx Coilovers
I just installed my Cusco mounts, and I used the same wrench with no problem. It is difficult to get your hand around the wrench. What I did was put the wrench on the bolt and slid a long socket with an extension attached to it over the open end of the wrench. This gave me plenty of leverage. I think I used like a 12mm long socket.
Old 03-31-2008, 04:07 PM   #28
Car: My06 WRB w/ Gold STi
Fav Mod: JDM Headlights and JDM Rear Fog
I did two of these in one day but my uncle down the street has a lift. It makes a nice difference and is very worth it.
WRB Kid is offline   Reply With Quote
Old 04-01-2008, 05:50 AM   #29
Car: 2006 STi
We are all set, finished them last night!
Old 04-05-2008, 03:38 PM   #30
Car: '06 SubaruImprezaSTi
Fav Mod: Full-Race exhaust manifold, ACPT CF Driveshaft
Now here's my issue today...............I've got MY06 with the one piece sh**y rubber mount. It was already broken, so I don't have to worry about how hard the back bolt is to get to. But It's saturday and none of the dealers in the area have the bracket that bolts to the motor. Anyone have this bracket?!!! Help.
i-Club
slicknick112 is offline   Reply With Quote
