Old 09-15-2007, 03:26 PM   #1
Car: 00 Legacy GT LTD
Fav Mod: Projectors.
Default DIY: Wrap shoulder harnesses around a harness bar (Using a 3-Bar Slide) *ATTN crookid
DISCLAIMER: Use of this DIY is for informative purposes only. Neither writer nor forum owner assumes liability for any results from using this DIY. Harness installs are very important, and should only be done by a qualified technician. Serious injury, up to and including death, can result from improperly installed harnesses. CONTINUE AT YOUR OWN RISK!
Its really hard to describe, so the pics will do most of hte talking. Of course, youll be wrapping around a proper harness bar, not a paint can.
If your harness is already wrapped up (some are shipped with the harness wrapped around air..some have the harness wrapped around, say, a snap in clip), disassemble it.
1
Start with the 3-Bar Slide about 16" from the end of the strap.
Pull the slide as close as possible to the bar. THIS IS VERY IMPORTANT!!! The further the bar ends up from the slide, the more you risk slippage under pressure.
5
6
The end of the strap should be AT LEAST 4" from the edge of the slide. Here I have 5"
There..I tried. Any questions just ask. These are the Schroth Profi II ASM FE 4-points..
Next on the DIY List: How to wrap a snap in clip to your harness, and how to install a 4-point harness.
blk rex is offline   Reply With Quote
Old 09-16-2007, 11:18 PM   #2
Car: 06 FPGREENSTI SOLD
Fav Mod: 04 GMC Sierra 2500HD Crew Cab Duramax Diesel
Send a message via AIM to BlackSTI2006
Default Re: DIY: Wrap shoulder harnesses around a harness bar (Using a 3-Bar Slide) *ATTN cro
nice.....want to come install my sparco 4 point for me this week.....i installed the rollbar today
BlackSTI2006 is offline   Reply With Quote
Old 09-17-2007, 12:23 AM   #3
Yea give me a call..and you got Sparcos and not Prodrives?
Old 09-17-2007, 08:51 AM   #4
i ordered prodrives but its a hit or miss item for some places stocking them....waiting to hear back from the kid at rally sport direct.....dan @ mach v told me they had some comming in....so im waiting for someone to get them in then ill just 2 day them or somethin...
i got a sparco 4 point for dirt cheap in blue......that will be here tomorow actually, the guy shipped it out today and fedex says itll be here tomorow
Old 09-17-2007, 09:39 AM   #5
Car: 04 WRB STi
oh do post the 'diy 4 point harness install'
i just got mine in today
jonnyboi is offline   Reply With Quote
Old 09-17-2007, 11:11 AM   #6
I can either do do the DIY when I help Chris, or I can take mine out of the car and reinstall it.
My snap in links actually came in today..took all of 5 minutes to put in the car..
Old 09-17-2007, 11:12 AM   #7
Car: 04 WRB STi
thing is, i just dont know how to put the bottom straps in.. the ones that go in the stock belt bolts.... is there a special way to put them in?? or just unbolt... put in harness.. and bolt back in???
Old 09-17-2007, 02:15 PM   #8
Unbolt, put in harness (closest to the car), rebolt. Thats all..
Old 09-18-2007, 03:37 PM   #9
Wow..I helped BlackSTI2006 put his in today and the Sparcos were ridiculous..the 3-bar slide was so tight we had to use a small screwdriver to push the belt through at Step5 and pull with pliers..
..those should DEFINITELY not slip Chris..
