Old 09-11-2007, 11:00 PM   #1
Car: BLOBEYE SYNDICATE ST
Fav Mod: N-E thing JDM
Default Installing a Blitz R vit i color...
Its simple as the kit is PnP..Comes with all the neccessary hardware but it doesnt have a mounting plate like how APEXi provides for theirs..
Product:
1st.Disconnect the negative terminal on the battery..
2nd.Find your desired location for the module to be placed.
3.Connect the female connector from the display harness into the Male connector of the Main harness.
4.Connect the IGN male connector from the Main harness with the female connector of the cigarette lighter plug.
5.Now connect the big blue male connector from the Main harness into the obd II port scanner/ diagnostic connector of the vehicle located beneath the steering column near your left foot(when in normal driving posture).
6.Connect the negative terminal of the battery back on to the battery.
7.Get into the car and plug in the cigarette light plug and voila, its turned on..
Give it a couple seconds after the module turns on as it doing an automatic inquiry(firmware). Then follow the instructions in setting it up.
Then ENJOY n show it off..Honestly when I bought it, the seller told me that BLITZ havent tested it on a impreza and only tested it on a Toyota and Infiniti but after installing it and checking the chart list for compatibility, it works for all the imports from honda,mitsubishi,nissan, and even daihatsu!!
I will post pics up later.
twilight_samurai is offline   Reply With Quote
Old 09-11-2007, 11:38 PM   #2
Car: 04 Platnm Silvr STi
Fav Mod: GT35R 450WHP Pump No Meth
Default Re: Installing a Blitz R vit i color...
So this unit is pretty much like the scangauge2 I am assuming?
Old 09-12-2007, 12:09 AM   #3
Yeah, except the fact that it doesnt have a scan tool to pull codes.But allows you to adjust your fuel curves like the APEXi SAFC II..
Old 10-20-2007, 02:45 AM   #4
Car: Silver Euro 07 STi
Hi any updates with your blitz R vit i color? Thanks
Product:
