Old 08-25-2007, 11:13 AM   #1
Fav Mod: Fujitsubo!!!!!!!!
Default How to: changing 6MT trans oil
Tools that you need (not shown is a oil dump container to drain your old oil and washers)
Different specs about the torqs and such.
Start by jacking up the car and setting up everything.
again, another 2 holes how-to
A better picture of those 2 drain plugs.
I started by the trans plug. Take your torq bar with the 21MM socket and sqeeze it out. Watch out, lots of oil will be pouring down.
Take your 14MM and torq wrench, unbolt this plug out and let drain. At the point, you can remove the dipstick so it will be draining faster.
I let both of them drain for a good 10 min.
Since I was on jackstand only on the front, I jacked up the rear of the car and some more oil poured out, another maybe 2 min.
Remove the oil pan and replace the 2 plugs.
just a little view of those plugs.
Foo_Blyat:
Well, it says to change the washers so for those of us who want to be extra safe...
Clutch side - 803926070
Oil Pan - 803916080
insert the funel into the trans hole and fill it with your oil
Check the level of your oil and you are done!
I'm sorry, I couldn't get a better picture of the dip stick.
Rennes is offline   Reply With Quote
Old 08-25-2007, 11:37 AM   #2
Fav Mod: protune
Default Re: How to: changing 6MT trans oil
Awesome how-to, i have to do this soon. Did you just reuse the washers? If not do you have part #'s?
thanks again
stiman1 is offline   Reply With Quote
Old 08-25-2007, 11:44 AM   #3
I don't see why you would change the washers, you should be fine
They are very thick washers actually, they wouldn't "crush" like the crush ring from the motor oil plug.
Old 08-25-2007, 11:47 AM   #4
Car: 06 STI
Very comprehensive how to. Thanks, I will be doing my next trans oil on my own.
06naSTI is offline   Reply With Quote
Old 08-25-2007, 06:28 PM   #5
Car: 04 STI JBP
Fav Mod: LC
What exhaust is that ?
Mustangkilla is offline   Reply With Quote
Old 08-25-2007, 06:36 PM   #6
Fujitsubo power getter + COBB catted downpipe
Old 08-26-2007, 04:55 PM   #7
Fav Mod: raw carbon fiber
Again, good how-to, just read your rear diff too. I'm marking these for future reference.
SilverSurfer is offline   Reply With Quote
Old 09-10-2007, 01:57 PM   #8
Car: 2006 Subie STi
Fav Mod: Turbo-back exhaust
Send a message via AIM to FastieMagee06
When should you do this service? Im almost at 17000 miles, I was going to do it soon with my diffs.
FastieMagee06 is offline   Reply With Quote
Old 09-10-2007, 02:13 PM   #9
Car: 06 Subaru WRX STI
Fav Mod: air freshener (mmm...squash)
Very nice write-up!
How do you like the Motul? Did you have grinding or crunching before the change?
halfbr3d is offline   Reply With Quote
Old 09-10-2007, 02:53 PM   #10
Car: 06 Aspen white STI
Send a message via MSN to whitestar
Nice write up!! going to do this once my motul oil arrive....
whitestar is offline   Reply With Quote
Old 09-16-2007, 11:49 AM   #11
Fav Mod: Turbosmart BOV
Send a message via AIM to bulgarianfreak55
awesome...just awesome
bulgarianfreak55 is offline   Reply With Quote
Old 09-27-2007, 11:46 AM   #12
Car: 07 S204 WannaBE
Well, around 2k miles on my car i did a coilover install and one off my boots came off from the tranny and leaked a lot of gear oil out. I went to pep boys and the only good brand i found was Royal Purple so i topped off my tranny with that. Ever since then my gears have been extremely loud and sometimes (rarely) grind.
Now im at about 15k miles where a tranny fluid replacement is recommended, so today i got Motul 300 and plan on doing this oil change today.
Thanks for the awesome write up, i also plan on doing my rear diff (using your write up) in the next day or two.
Foo_Blyat is offline   Reply With Quote
Old 09-27-2007, 11:52 AM   #13
Car: 06 WRB GOLD STI
Fav Mod: DDX7017
hey very nice write up! I appreciate it!
Old 09-29-2007, 10:13 AM   #14
Oil Pan - 803916080
are the two washers.
Old 09-29-2007, 10:26 AM   #15
Fav Mod: Zzyzx Coilovers
Thanks for the write up.
