Old 05-14-2008, 10:20 AM   #76
Car: 07 STI
Fav Mod: 05 taillights
Send a message via AIM to Subaru13
Default Re: How to: changing 6MT trans oil
Do our trannies have any sort of filter that we also need to change??
Subaru13 is offline   Reply With Quote
Old 05-14-2008, 11:07 AM   #77
Car: UGM 2007 STI Limited
Just make sure you get all the metal off the magnetic plug and drain both plugs.. and that's it.
07STILimited is offline   Reply With Quote
Old 05-15-2008, 01:34 PM   #78
Car: 05 Subaru Wrx STI
Fav Mod: Greddy Tic
No trans filters for our car only automatic cars have filters
harout18 is offline   Reply With Quote
Old 06-26-2008, 09:33 AM   #79
Car: UGM 07 STi L #95
Fav Mod: oil drain valve
Just used 75W140 Motul gear oil and did my rear differential last night and will be doing the transmission tomorrow. Apparently this is good for front and rear differentials.
STISubSilver is offline   Reply With Quote
Old 06-26-2008, 10:24 AM   #80
Orwell was an optimist.
Fav Mod: Track time
NO, that is NOT it.
There is a doughnut shaped magnet stuck to the oil pickup under the tranny pan.
I would recommend removing the pan and cleaning the magnet with each change.
I'd also take a look at the screen in the pickup and make sure it is free of debris.
Use suby silicon sealant or RTV gasket maker to seal the pan back up after you clean the old gasket off.
Old 06-26-2008, 10:37 AM   #81
Fav Mod: Track time
Good luck!
Old 06-26-2008, 06:28 PM   #82
Originally Posted by fullerton View Post
NO, that is NOT it.
If Subaru intended for you to remove the pan with every change then why is there a plug in it?
Old 06-26-2008, 06:44 PM   #83
Fav Mod: Track time
They also tell you not to race your car and to change your oil with dino oil every 3750+ miles...
But, be lazy. It's your car.
Me, I'll spend the extra 10 minutes and make sure my car is cared for properly.
Old 06-26-2008, 06:52 PM   #84
^Amen, if its messy already. Who cares if 10 more minutes of mess will get some shavings out. They add up.
Old 06-28-2008, 04:46 AM   #85
Well, finished the trans-side and used the 75w140... so far, yummy!
Old 06-28-2008, 06:51 PM   #86
Car: 06 STi
Originally Posted by chanders View Post
How difficult is it to take off the pan? I would like to just to see if I have any filings in there as I have had some grating in 4th..
I was wondering the same thing and found this thread.
transmission oil pan removal/install. Help!
gbSTi is offline   Reply With Quote
Old 06-28-2008, 07:30 PM   #87
Car: 06 STI
^^Yeah, I started that thread. I was going to remove the pan but I decided not to after spending 15 minutes trying without success. I probably should of wacked it with a mallet but I was hesitant to mess anything up. I bolted everything back up and filled the tranny with conventional valvoline 75w-90, so far so good (feels pretty much the same as before).
For those that want to see the magnet under the pan.......check this thread out. Great pics!
The filter under the pan (6mt)
NO, that is NOT it.
Do you have to remove the pickup (thing that the giant magnet is stuck to) to inspect the screen or can you view the screen from the hole to the right of the magnet without removing anything? Do you know the torque spec on the bolts for the pickup?
Also what is your method for removing/breaking the silicon seal between the pan and transmission? I tried using a razor blade and spackling putty knife and it didn't seem possible with those tools.
Deuce Cam is offline   Reply With Quote
Old 07-04-2008, 07:50 AM   #88
Car: 05 OBP STI
Can someone tell me how much bottles do i need to buy and how much does it takes to fill the gearbox up.
wpwm020 is offline   Reply With Quote
Old 07-04-2008, 08:59 AM   #89
Fav Mod: Zzyzx Coilovers
For those of you who don't know, the 07's do not have the magnet in the oil pan.
07, Magnet in Tranny Oil Pan
JD_STI is online now   Reply With Quote
