Old 10-08-2007, 11:18 AM   #31
Fav Mod: Rustoleum Flat Black
Default Re: How to: changing 6MT trans oil
Originally Posted by Foo_Blyat View Post
Well, since subaru over torqued the hell out of the oil pan drain plug, i ended up stripping it down.
Thanks to Irwins 14mm Bolt-Grip socket and 4 bloody knuckles, i finally got it out.
I think they torque that plug to like, 200ft/lbs. I stripped that doo-doo outta mine too. lol
grambo is offline   Reply With Quote
Old 10-08-2007, 11:27 AM   #32
abracious
Fav Mod: Track time
Same thing happened to me. I ordered a new pan (just in case) and it came with a bolt torqued in there so much i couldn't get it out either.
i just take off the pan now, anyways. that way I can clean the magnet under it.
anyone need a new 6MT tranny pan with bolt?
Old 10-08-2007, 12:42 PM   #33
Car: 06 Aspen white STI
Send a message via MSN to whitestar
just use a braker bar to loosen it, mine was pretty easy for some reason. Lucky me....
whitestar is offline   Reply With Quote
Old 10-13-2007, 12:06 PM   #34
Car: 06 White/Gold STi
Fav Mod: The Driver Mod
Wheres a good place to order motul from?
scoobtothenoog is offline   Reply With Quote
Old 10-17-2007, 09:45 AM   #35
Car: 07 S204 WannaBE
Motul Lubricants is where i ordered mine from. Funny thing is, i found their site after using "motul" in the google search. They had the best price around before shipping, and with shipping included. Even beating my local shops OTD price.
Foo_Blyat is offline   Reply With Quote
Old 10-17-2007, 11:09 AM   #36
I order mine from LTB Motorsports for free shipping and their prices are low. Check it out guys. Due to Fedex & UPS regulations we can not ship oil via Express shipping, we will only ship via ground.
Old 10-17-2007, 11:24 AM   #37
Car: OBP 06 STI
why is everyone using Motul 300? Shouldnt we be using Motul 75w90?
jsnuff1 is offline   Reply With Quote
Old 10-19-2007, 11:28 AM   #38
Motul300 is rated 75w90, i mean, just look at the bottle.
Old 10-19-2007, 12:45 PM   #39
Car: 05 S2000
Motul 300, more specifically Motul Gear300 is the product name, the numbers do not signify the oil weight.
MOTUL Gear 300
eXstasy is offline   Reply With Quote
Old 10-19-2007, 10:58 PM   #40
Car: OBP 06 STI
ok so whats the diffrence between motul 300 and motul 75w90?
Old 10-21-2007, 06:12 PM   #41
Motul 300 is just simply better due to the fact is fully synthetic tranny fluid. Its meant for racing application, so thats your choice for your subie.
Old 10-29-2007, 08:19 AM   #42
Car: '07 SWP STi
Fav Mod: NEW BRAKES!!!
Send a message via AIM to Kickstand
PLanning on doing this this weekend, and I went to dealer who I knew carried Motul, and he gave me motul300 75-145. I thought it seemed funny, but the parts guy has an STI and says he uses it in both his tranny and Diff. Anybody have any insight on that.
Kickstand is offline   Reply With Quote
Old 11-11-2007, 09:56 AM   #43
Fav Mod: protune
Just did this today, everything went smoothly....
except tranny fluid smells like ass!!! Still trying to wash the scent off my hands
stiman1 is offline   Reply With Quote
Old 12-16-2007, 06:11 PM   #44
Car: Aspen White 04' STi
Fav Mod: Boost Sticker
I dont see why you couldn't use that, i'm using motul 300 in both my tranny and rear diff and i havn't had any problems yet. The bottle even says for use in transmissions and differentials.
So... i think you'll be fine.
cbr_boi is offline   Reply With Quote
Old 12-16-2007, 06:36 PM   #45
Car: 04' PSM STi
Fav Mod: Stg. 2
A little tip that may help some of you out. Since the pan washer looks to be made of copper you can try putting the socket on the bolt and tapping it with a hammer to crush the washer a little. Don't hit so hard you dent your pan in but that should relieve some pressure and make loosening the bolt easier. A little penetraing oil helps too. Also, another method is to try and tighten the bolt a little which will again squish the washer a little and will make removal easier. The only problem with the second method is you may still strip the bolt. However, I wouldn't do this to the clutch housing(torx) bolt using the socket. For that you would need a large faced hammer or punch that wouldn't damage the area where the torx fits into. Hope that helps.
eroc263 is offline   Reply With Quote
