Old 08-23-2007, 02:29 PM   #1
Car: 07 euro type sti
Default Where To Install Turbo Timer ?
Hi. I'm a newbie to this forum and subaru. I have purchased a MY07 Impreza Sti a while ago. I have done some mods to my car and now looking for a suitable place to mount my HKS turbo timer therefore It will be great if any of you can post your installation pics or possible options. Any comments will be appreciated. Thanks.
extreme sti is offline   Reply With Quote
Old 08-24-2007, 10:50 AM   #2
Fav Mod: Rustoleum Flat Black
Default Re: Where To Install Turbo Timer ?
PM HWYKING. He helped me out alot with this install. If you have LoJack....avoid it all together.
grambo is offline   Reply With Quote
Old 08-24-2007, 11:13 AM   #3
Car: 05 Subaru WRX STI
Fav Mod: COBB TUNN
Unless you've changed your turbo, it's really not necessary since our turbo's are water and oil cooled. Just a few minutes of sitting after a "hard" run is all that is needed.
whtwrx1991 is offline   Reply With Quote
Old 08-24-2007, 12:37 PM   #4
Car: 06 STI
Fav Mod: Your MOM!!
if you must install it, which yes there is no reason to have it but like everyone says to just sit for a few minutes after you drive, well i dont have those few minutes being in the army so, you could install it in the cigarette ashtray spot, just take some needle nose pliers and break away the plastic so that it fits and velcro it down, and route the wires up through the dash and ground the ground wire to somewhere near the shifter assembly and just tap into the parking brake wire.... done
Old 08-24-2007, 12:56 PM   #5
I actually made areplica of the HKS unit out of wood to use as a model during the proces of installing it in the fuse-box door. If you own a Dremel with some decent cutting discs (steel...not grinder disks) you can carefully cut the two bottom corners of the fuse door and actually close the door with the unit in the dash to hide it once it is wired. The ashtray is a standard spot though.
I've seen an HKS advertisement where it was mounted in the driver's side a/c vent in teh center dash area.
I liked the idea of hiding the unit though.
Old 08-24-2007, 01:14 PM   #6
Car: 06 STI
Fav Mod: Your MOM!!
thats why i put mine in the ashtray, its easy enough to get to and its hidden when i close the ashtray and since i would never smoke in my car, well i dont smoke anyways but still... i dont even open the ashtray anyways so no one knows its there... i only use it on really hot days or if i drive pretty far.. most of my drives are like 3 or 4 miles or so. so i dont use it that often but hey it only cost me 20 bucks with the harness so it was worth it....
Old 08-25-2007, 11:10 AM   #7
thanx for replie...ı installed it into the fuse box..
Old 09-20-2007, 03:35 PM   #8
Car: 02 WRX with an extra half litre
Fav Mod: STi Block
Thats where mine is. Oh and since the pic I made the lines better so no need to slam my modding skills
STiBottom is offline   Reply With Quote
Old 09-20-2007, 03:37 PM   #9
Car: 06 OBP STi
Fav Mod: My girlfriend
why is this?
ptiz is offline   Reply With Quote
Old 09-20-2007, 03:37 PM   #10
Car: 06 STI SGM
Fav Mod: seatbelts
Send a message via MSN to boost_happy
If we can't slam your modding skills on the timer can we slam you for missing a gauge in your tri pod.
boost_happy is offline   Reply With Quote
Old 09-20-2007, 03:47 PM   #11
Fav Mod: STi Block
Haha yeah thats there too now.. I was waiting on a back ordered oil pressure gauge at the time so you got me there
Old 09-26-2007, 06:36 PM   #12
anyone have the answer to this?
local is offline   Reply With Quote
Old 11-28-2007, 05:17 AM   #13
Car: 2005 STi
Fav Mod: P&L Race TBE
Send a message via AIM to Markiavelli
So some pics would aid my install (so i know what i'm going for).
Can you guys who installed in the ashtray post some pics?
I am going to buy the HKS Type 0 and would love to put it in the ashtray (after removing some of the plastic first b/c the timer is too big by like 2mm or some tiny ammount).
Markiavelli is offline   Reply With Quote
