Old 08-13-2007, 08:44 AM   #1
Car: 07 STI UGM
Default Exhaust donut gasket question
Getting ready to bolt up my invidia g200 to stock dp, I have read alot of debate between reusing the donut gasket or removing it and using the provided crush gasket, any recommendations for best connection, a dp is hopefully coming in the near future.
bwoosti is offline   Reply With Quote
Old 08-13-2007, 09:55 AM   #2
Car: 06 STI UGM
Fav Mod: Right Foot!
Default Re: Exhaust donut gasket question
I have tried a lot of different things but mine still leaks a little
I've pretty much given up because it will cost me like $40us for a gasket to get shipped to me....
Hopefully someone else will have some more insight!
Jay
jaydow11 is offline   Reply With Quote
Old 08-13-2007, 10:31 AM   #3
Car: 07 STI UGM
So what do you feel has been the most efficient way... so I dont have to redo my install over and over.
Old 08-13-2007, 11:13 AM   #4
Car: 06 STI UGM
I tried to make my own gastget which actually worked pretty good, but I just used a sheet of thicker Alum.... it's still not thick enough so that's why I still leak...
I don't know... I would probably buy this if it didn't cost me $20us to ship to me....
http://www.rallysportdirect.com/shop...ce482dba54b26e
Old 08-13-2007, 02:04 PM   #5
Car: 07 STI UGM
That gasket looks like the 2 they sent went the g200, so just take donut off and use this...or leave donut and that on...
Old 08-13-2007, 03:26 PM   #6
Car: 05|WRB|STi
Fav Mod: Cobb Stage 2
Send a message via AIM to SoaReS
I'd just use the supplied gaskets.
SoaReS is offline   Reply With Quote
Old 08-13-2007, 04:17 PM   #7
Car: 07 STI UGM
So take out the donut gasket and use the supplied gasket....any one have any other ideas.
Old 08-17-2007, 03:55 AM   #8
Car: 06 Arctic White STI
I'm going on the assumption that the g200 is a flat 3" flange designed to mate to a 3" downpipe. As such your going to be trying to seal a flat surface to a curved surface that looks like this.
It's not going to happen.
Pry the donut off so your factory pipe has a nice flat surface like this.
Clean the flat surface up a bit then use the gasket that came with the g200 or go to napa and buy a generic 3" exhaust gasket for about $10.
Vorpal Blade is offline   Reply With Quote
Old 08-25-2007, 07:27 AM   #9
Car: 06 WRC Blue STi
Fav Mod: AP 2.0 Stage 1
Smile Re: Exhaust donut gasket question
I've done the g200 install (about 2 weeks ago). You cannot install it w/ the doughnut gasket. Use the crush gasket that came with it, or get the 3 inch generic at a parts store.
tbmtb is offline   Reply With Quote
Old 08-25-2007, 07:30 AM   #10
i eat cones
Fav Mod: catless
i just installed my g200. i used the crush gaskets that came w/ it. i dont think the donut gasket will fit. i have no problems with mine with the crush gaskets.
