Old 08-12-2007, 01:53 PM   #1
Car: Silver 05 WRX STi
Fav Mod: My RFL Turboback Exhaust
Send a message via AIM to Gq1304
Exclamation water in headlight what can i do to fix it??
when i did the DIY clear the headlight apparently water seaped in during a car wash... the headlight does not work, i took the headlights out and there was little water in there i rebaked it and resealed it... still does not work does anyone know what is damaged when water gets into the headlight? i dont know what else to do please help!!!!
Gq1304 is offline   Reply With Quote
Old 08-12-2007, 05:55 PM   #2
Car: Silver '04 Anthraci
Default Re: water in headlight what can i do to fix it??
If one is out then switch the bulbs and if it now works then you need to buy a set of bulbs. If it still doesnt work could be the ballast. If both your lights are out then test the voltage on the system. If everything looks good then buy a set of bulbs. Good luck.
AARONH is offline   Reply With Quote
Old 08-15-2007, 01:32 PM   #3
yeah thanks, i did the shake and baked and it it works now thanks tho for the help
