Old 08-11-2007, 08:28 AM   #1
Car: 07 UGM STi Ltd. #537
Fav Mod: Exhaust
Default Two shims/backing plates on front brakes?
Hi, I'm swapping out pads and there is 2 items behind the stock pads, one is the size of the pad, and the other is a partial piece that the pistons actually contact. Do I re-use both of those things on the front, or just the shiny partial that contacts the pistons. The new pads have a piece of metal on them that is approximately the same thickness as the full size backing plate. I have the car on jacks right now, so a prompt answer would be awesome! Thanks.
buzz wrecker is offline   Reply With Quote
Old 08-11-2007, 08:41 AM   #2
Car: 06 STI
Default Re: Two shims/backing plates on front brakes?
leave them out. make sure to use some caliper grease or somthing with the new pads.
my 06 had a really thin shim that the pistons made partial contact. I used hawk hps and I left those out. What pads are you using?
06naSTI is offline   Reply With Quote
Old 08-11-2007, 08:47 AM   #3
Fav Mod: Exhaust
I'm going with the Satisfied OEM replacement pads from tire rack. This car will see little or no track time, so I'm just going with a lower dust pad. It was $75 for front and rear pads, so we'll see how this goes. I left the partial piece in, and took out the big shim. I think that should about match how it was originally set up. I am using the goo that came with the pads between the shims and the pads.
Old 08-11-2007, 09:06 AM   #4
Car: 06 STI
Sounds good.
Let us know how those pads work out. I remember seeing another post about someone wanting those.
Old 08-11-2007, 09:13 AM   #5
Fav Mod: Exhaust
Cool, will do. Thanks for the assist!
Old 08-11-2007, 10:21 AM   #6
Car: '05 Subaru WRX STi
i got my pads from Tic, the stoptec/posi-quiet ones...i think something like 80 bucks for front and rear, but i did reuse the smaller shim with the backing plate that came with the replacement pads and lots of goo all around..... had them like this for about 4 weeks with "zero" noise coming from the pads
05_STi_WRB is offline   Reply With Quote
