Old 08-02-2007, 09:15 AM   #16
killer ants in your pants
Trader Rating: (21)
Default Re: EBay TMIC install problem!!!!
i would grind the welds to try to save the bracket so you can just reposition it. buying stock from a hardware store and modifying it to hold works. but imo like i said before, every time i see it, it looks ghetto.
Old 08-03-2007, 11:46 AM   #17
Fav Mod: TBE
Ok so I got the bracket problem taken care of. I broke out the MIG welder and went to Home Depot and got some steel. After a lot of bending, cutting, and welding I have a bracket for it. So I didn't have to hack up the TMIC itself.
But now my problem is that it seems like the Y-Pipe is too short. Where the coupler attaches to the turbo seems like it needs to be about 1 inch longer. I've been reading about people having to extend the Y-Pipe and I think that's what I need to do. Anyone with an EBay TMIC have to do that?
Old 08-03-2007, 11:53 AM   #18
Fav Mod: Long dirt roads
use your stock y-pipe also make sure you port your y-pipe inlet.
layza4sti is offline   Reply With Quote
Old 08-05-2007, 04:00 AM   #19
Car: 2007 wrx
Send a message via Yahoo to wesley1202
we have the same problem . i bought the same tmic as yours . i have a 2007 wrx and i still have not used the tmic because of the 2 side brackets and the y pipe was short and the tmic hits the throttle body. am pist off with this . so if you can help me on what you have done alredy i would appreciate it ...
wesley1202 is offline   Reply With Quote
Old 08-05-2007, 07:24 AM   #20
Fav Mod: TBE
Do you have the Drive By Wire throttle body? If so then you have to take off the lip on the TMIC outlet. This is what it looks like now. Oh yea I put the STi logo on it yesterday.
With that lip cut off it gave me enough clearance to get the driver's side bracket lined up and mounted. The problem was that I had to fab my own bracket for the passenger side. I got some steel from Home Depot and after a few hours of measuring, cutting, and welding I have a bracket. It looks like crap but you can't see it when the TMIC is on.
If you have a WRX you might want to take a look at this thread on Nabisco:
http://forums.nasioc.com/forums/showthread.php?t=825869
Old 08-05-2007, 10:26 AM   #21
Car: 08 sti
Fav Mod: New Cars
nice STI logo! can you put up pics of it intalled on the car?
JuniorRSX is offline   Reply With Quote
Old 08-05-2007, 12:05 PM   #22
Fav Mod: TBE
The TMIC is still sitting on my floor right now. I've been working on a few other things and haven't had time to wrestle this thing back in place again. But I'll post up pics once I get it back in.
Old 09-07-2007, 12:51 PM   #23
Car: 04 Sti Wrb on Silver
Any updates? Im thinking of buying a top mount from ebay but dont know from ho will I buy it.
Would like to see the pic's of the intercooler instaled
Old 09-07-2007, 05:07 PM   #24
Car: 06 STI SGM
Fav Mod: seatbelts
Send a message via MSN to boost_happy
Originally Posted by WRC~06~STi View Post
yeah man that would be a good idea to get it plasma'd off but make sure it's someone you know does good work, b/c you don't want them cutting into the actual cooling part of the IC. but it would be easy to cut that off and move it, reweld it in the right place. good luck
When I heard the words plasma off and intercooler in the same sentance I started to cringe. Ooooo, not a good idea, unless you want to see what a whole bunch of melted coke cans looks like.
boost_happy is offline   Reply With Quote
Old 09-07-2007, 09:05 PM   #25
Car: 05 STI - Cobb Stg 2
Fav Mod: Curb Feelers (driver side)
Originally Posted by V8Huntr View Post
PWND!
RAS_STI is offline   Reply With Quote
Old 09-07-2007, 09:19 PM   #26
Car: '06 Aspen White STI
Fav Mod: Recaro SPG3,Ohlins & RA-R's
Mig welding steel to aluminum? Huh?
ESSTEAEYE is offline   Reply With Quote
Old 09-09-2007, 10:04 AM   #27
Fav Mod: TBE
No I made a bracket out of steel which the TMIC bolted to on the left side.
Sorry I didn't post up any pics of this installed. I just got done taking it out for good actually. This TMIC was ok while it was installed, saw a few good gains from it, but was making my car run too rich. I was getting a lot of backfiring and I could smell a hint of fuel in the exhaust gases.
IMHO I would never buy one of these things again! It was a PITA to install and needed a lot of fab work to get it to fit properly. I wish I would've just bought an APS and been done with it. I guess you get what you pay for....
