Old 07-31-2007, 08:15 AM   #1
Is Scared Of Kevin...
Default How To: Install JDM Auto I/C Switch
Alright guys, here is the super easy how-to on how to install the jdm auto i/c switch. I bought the switch from So JDM ( great vendor, but make sure to request the free shipping upgrade otherwise it will take a week to get to you). also, for those of you wondering the advantage of upgrading to the jdm auto switch is that it essentialy it works as a on/ off switch.....no more continually pushing the button! you push it once to turn it on, and again to turn it off..
this is what i got from SO JDM
here is how it looks from the factory
here is the switch we are going to be installing
1) pop out the the fuse box panel below...
2) use your middle finger to depress the tab on the bottom of the button to pop it out....after that it will look like this.....
3) then pull the switch out
4) depress the tab on the back of the plug to remove the switch
5) now comes the tricky part that not many people know about.....in the switch thier is a insert that allows the switch to clip into the plug, however the jdm switch is designed backwards so you have to pop out the usdm switches's insert with a small flat blade screw driver, and insert it into the jdm one....here is the jdm switch with the usdm insert inserted.....its the white piece in the inside of the switch..
6) snap it back in, followed by the fuse box cover, and your done it should look like this
now push the button with your key in the ign position and check to see if it works!
Mods please notice my great how-to i need more pm box capiblity!!!
MK
MKTURBO is offline   Reply With Quote
Old 07-31-2007, 09:49 AM   #2
Car: 07 STI
Fav Mod: Zzyzx Coilovers
Default Re: How To: Install JDM Auto I/C Switch
so when it's on auto does it just constantly spray?
Old 07-31-2007, 11:55 AM   #3
yeah, when its turned on
Old 07-31-2007, 04:56 PM   #4
Fav Mod: HKS carbon ti
Send a message via AIM to ardevas09 Send a message via Yahoo to ardevas09
looks like a nice improvement
ardevas09 is offline   Reply With Quote
Old 07-31-2007, 05:13 PM   #5
Car: 01 JDM STI
Fav Mod: JDM cupholders
You know you could have left the factory switch in, added the JDM switch and done the boost reference mod. You leave the switch on and when ever you hit a certain boost threshold your auto switch will spray for 5 seconds.
escos is offline   Reply With Quote
Old 07-31-2007, 05:17 PM   #6
Car: 01 JDM STI
Check this thread out
How To: Automatic Intercooler Sprayer (boost referenced)
Old 08-01-2007, 07:47 AM   #7
yeah i know all about that....i didn't want to do that......however i couldn't of left my factory switch in because i have no where to put it!!!
Old 08-01-2007, 09:35 AM   #8
Teh Other White Meat
Trader Rating: (21)
repost! jk
mk do the boost reference mod. you won't regret it. plus you'll probably knock a second or two off your times b/c of a cooler tmic.
Old 08-03-2007, 07:32 AM   #9
i didn't want to mess with it because i plan on using the waterspray tank for meth........
Old 08-05-2007, 10:15 AM   #10
Car: 2005 Subaru WRX STi
sweet thank you just what I was looking for so take the connector off the stock and transfer to the jdm? Thanks it? Thank you
tappintherockies is offline   Reply With Quote
Old 08-05-2007, 10:30 AM   #11
Car: 06 OBP STI
Fav Mod: Credit Card Bills
Send a message via AIM to P1ayB01 Send a message via Yahoo to P1ayB01
Does the switch light up like the factory switch? I am planning on doing this mod shortly, since my OEM switch no longer lights up. If I follow this will the new switch light up... anyone know??
Thanks,
Josh
P1ayB01 is offline   Reply With Quote
Old 08-05-2007, 11:06 AM   #12
yes the switch lights up perfectly just like the factory, no modifications nessacary!
Old 08-06-2007, 08:14 PM   #13
Trader Rating: (21)
Thanks,
Josh
the bulb probably burned out. take out the switch and you can replace the bulb.
Old 08-06-2007, 08:16 PM   #14
Car: 06 OBP STI
i talked to a dealer, and they said you can't just replace the light, you have to replace the switch...., any1 shed info on this? Either way, if I buy the JDM switch, it will have the bulb in there anyways right?
Thanks
Old 08-06-2007, 08:23 PM   #15
Trader Rating: (21)
bs the two round colored pieces (one blue one grey on the jdm i can't remember what color they are on the regular switch) on the side of the switch house the bulbs. twist the piece counter-clockwise with a screwdriver and the piece pops out with the bulb attached. one doesn't have a bulb attached. the bulbs are at radio shack.
