Old 08-06-2007, 08:41 PM   #16
Car: 06 OBP STI
Fav Mod: Credit Card Bills
Send a message via AIM to P1ayB01 Send a message via Yahoo to P1ayB01
Default Re: How To: Install JDM Auto I/C Switch
you rock dude, it's been so long since I'v had a light on the switch, what lights up, jut Water Spray right?..., or does I/C also light up
Thank You Sir when I get my car back from the body shop I'm gonna replace the light anyways, since it'll be really cheap.
Josh
P1ayB01 is offline   Reply With Quote
Old 08-06-2007, 10:23 PM   #17
Teh Other White Meat
Trader Rating: (21)
no problem. there's a slot that lets light through. it should light up all the letters.
Old 08-14-2007, 09:07 AM   #18
Car: WRB EDM 06 WRX STI
Fav Mod: Aerys 3"
hi, I have a problem; my german dealer won´t sell me the female ic switch harness connector ("subaru of germany don´t list this item"...)...any other options?
torquemada is offline   Reply With Quote
Old 08-14-2007, 09:14 AM   #19
Fav Mod: TBE
I have a quick question, how long does it take to completely empty out the IC Tank if you would leave this on? I've always wondered that....
Old 08-14-2007, 09:15 AM   #20
Car: 07 STI
Fav Mod: Zzyzx Coilovers
Originally Posted by torquemada
hi, I have a problem; my german dealer wonīt sell me the female ic switch harness connector ("subaru of germany donīt list this item"...)...any other options?
Follow Wolfplayers DIY:
Here is Wolfplayer's DIY on the JDM Auto I/C Switch, thanks Wolfplayer!
How To: Automatic Intercooler Sprayer (boost referenced)
Instead of just replacing the stock switch you can leave that and add the JDM Auto switch, wire it up to a boost pressure switch, and set it to engage at your desired boost level. It works perfectly.
The boost pressure switch can be found here (ebay seller becoool):
http://cgi.ebay.com/ebaymotors/Boost...spagenameZWDVW[/quote]
Old 08-14-2007, 11:03 AM   #21
Fav Mod: Aerys 3"
thanks, probably my fault:
I need a second female connector for this little cutie to run both, the oem pushbutton and the jdm auto switch, and subaru of germany will not sell it to me, because they don´t list this article
Old 08-14-2007, 11:22 AM   #22
Is Scared Of Kevin...
i couldn't run both because i have no 1/4 din locations left, so i had to replace it......all my switch panels are filled
MKTURBO is offline   Reply With Quote
Old 08-14-2007, 01:46 PM   #23
Car: 07 STI
I need a second female connector for this little cutie to run both, the oem pushbutton and the jdm auto switch, and subaru of germany will not sell it to me, because they donīt list this article
I know what you are saying, but what I'm saying is you don't need it, look what Wolfplayer did:
http://www.bescaredracing.com/sti/in...l/DSC05612.JPG
http://www.bescaredracing.com/sti/in...l/DSC05614.JPG
Old 08-18-2007, 09:33 AM   #24
Fav Mod: Aerys 3"
ok, itīs done...in 10 minutes...first, I am a lucky guy!
There was a "blind switch", and guess what...and a female connector with some wires...cut three off, left another three in their place, connect two wires with the oem switch and...it works (only the control light donīt work, but who cares...)
Finished Product:
Old 06-03-2008, 09:56 PM   #25
Car: dark silver 05 sti
Fav Mod: All
Since you changed that, when does it go on????
Vinh021 is offline   Reply With Quote
Old 06-03-2008, 10:02 PM   #26
HowTo Contributor
Fav Mod: Cobb Stg 2 - Wrapped DP
Originally Posted by escos View Post
You know you could have left the factory switch in, added the JDM switch and done the boost reference mod. You leave the switch on and when ever you hit a certain boost threshold your auto switch will spray for 5 seconds.
i know this was an early post, but i thought i'd add my $0.02
The DIY is perfectly fine, but for just some out of pocket, you dont need to modify anything really... and the biggest selling point for this for me would be for use during Auto-x, when the boost referenced switch might not always be firing... turn this on and forget about it turn off at the end of the run and enjoy....
Old 06-03-2008, 10:33 PM   #27
Trader Rating: (21)
for me, I rarely remember to turn off my camera after a run. I usually have an extra 3 mins of video at the end of each of my runs because I forget to shut my camera off. Remembering to turn off the auto switch would probably be the same.
As it stands now, with the boost referenced mod, I run through half a tank of water after 1 day of autox. (6-7 runs averaging 45 sec a piece)
Regardless, either way is a great mod for fighting heat soak. The underside of my TMIC is always cool to the touch after a run even in July.
