Old 07-30-2007, 08:26 PM   #1
Car: 05 Subaru Sti
Fav Mod: Defi triple pod guages
Post How to Flush Radiator on Sti
Can somebody post some pictures of how to remove the plugs for the radiator as I just finished my 30K fluid change and everything went well. Except could not find how to drain the anti-freeze.
Please Help.
STIFun is offline   Reply With Quote
Old 07-30-2007, 09:00 PM   #2
Car: 05 Subaru Sti
Default Re: How to Flush Radiator on Sti
Please if anybody knows and can point me in the right direction I would appreciate it. Doing all the fluid changes before my upcoming tune for safety and maybe better numbers.
Old 07-30-2007, 09:09 PM   #3
Fav Mod: Starving my STI
Trader Rating: (12)
It's a plastic "bow tie" looking knob on the lower passenger side (right side) of the car. It can be removed with your fingers. There are 2 levels of removal... u can loosen and let it drip out... or remove completely and in combination with removing the fill cap, it will GUSH out.
Old 07-30-2007, 09:39 PM   #4
Car: 05 Subaru Sti
Well it sounds easy enough but does anybody have a DIY guide or some pictures as I was under the car and can't seem to find the bow tie looking plug. Where are they located by as I heard there are two also how do you remove overflow tank.
Old 07-31-2007, 08:53 AM   #5
Car: 05 Subaru Sti
Morning bump really need some Pictures or specific location where plugs are located for example by oil filter.
Old 07-31-2007, 11:51 AM   #6
Car: 05 Subaru Sti
Mid Afternoon BUMP still need help or DIY
Old 07-31-2007, 11:59 AM   #7
Car: 05 OBP STi
Fav Mod: AP
It's actually really easy to locate. Looking from the hood, look straight down on the passenger side and you'll see the bow knob. You just remove the undercover from the bottom of the car, turn the knob, and it will drain. Just be sure to remove the radiator cap (not the one on the actually radiator). You will need a funnel or something to help direct the fluid. Otherwise, it will splash on the subframe. So I don't have any pics, but I just did my fluid and thats how I did it.
wrxridah is offline   Reply With Quote
Old 07-31-2007, 12:07 PM   #8
Car: 05 Subaru Sti
Thanks will try this so which radiator cap are you talking about if not the one on radiator then where is this cap.
Old 07-31-2007, 02:10 PM   #9
Car: 06 STi
Fav Mod: Your Girlfriend Ridin Shotgun
Send a message via MSN to Inertia
um if you cant find the other cap you shouldnt be changing coolant.
Inertia is offline   Reply With Quote
Old 07-31-2007, 03:35 PM   #10
Car: 05 Subaru Sti
Well I just changed my fluid thanks for telling me where the bow tie plug was. Drained the radiator for a good 10minutes then flushed the system with 2 gallons of distilled water. Finally droped the car from the jack stands then filled radiator very slowly to prevent air bubbles. Then once radiator was full started the car with both caps open burped the car and let it idle then held 1.5 to 2K rpm then shut off car checked levels and put all caps back on.
Thanks Guy's
Old 11-28-2007, 02:35 PM   #11
Car: 05 WRB Sti
Fav Mod: Stage 2
any tips on how to twist that bowtie looking that. mines being a pita
ezsleeper is offline   Reply With Quote
Old 11-28-2007, 02:49 PM   #12
Car: 06 STI
Fav Mod: Prodrive oval tip
do you fill coolant on both openings? when you drain the oil from the bottom, does the top coolant drain also?
Old 11-28-2007, 03:12 PM   #13
100% More Wingless
Car: 05 STi + 08 OBXT
Fav Mod: baby seats
Is this what you are looking for?
Old 11-29-2007, 02:52 PM   #14
Car: MY06 STi (Silver)
Fav Mod: Haltech Interceptor
That was useful for me, thank you.
STiSkyHigh is offline   Reply With Quote
Old 12-01-2007, 07:27 AM   #15
Car: 05' STI
Fav Mod: Defi gauges, or TXS TBE or JDM sidemarkers...arg!
Arrow Re: How to Flush Radiator on Sti
So I changed my upper radiator pipe... Doing so I lost fluid, once I filled it back up I was at the FULL line via the overflow tank...
Now looking at it I am BELOW the low line...
What is going on?
Which cap do I pour fluid into? The one near the intercooler or the one that is on the radiator itself or do I pour it in the overflow tank?
Any help in the next couple would be great, I have to go to work... :-(
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
