Old 07-30-2007, 06:18 PM   #1
Fav Mod:
Default rally armor urethane mud flaps
mud flaps did not come with directions. How hard can it be, right? Well, the c and z shaped clamps dont even fit right over the existing holes, and they protrude inhibiting the stock plastic from being able to lay back flat. Any one else have this problem(05 sti). Thinking about just getting some black self center push tappers(or whatever u call them).
shortthrowsti is offline   Reply With Quote
Old 07-30-2007, 06:21 PM   #2
Fav Mod: Fabspeed
Default Re: rally armor urethane mud flaps
I had no problems on my 02 with them. There is a video on here, step by step on how to put them on
ACHAHockey is offline   Reply With Quote
Old 07-30-2007, 06:25 PM   #3
Car: 2006 Subaru Impreza
Fav Mod: Stage 2 - Protuned
Very easy install... follow the easy install video on this website..
DOMIN8 is offline   Reply With Quote
Old 07-30-2007, 06:43 PM   #4
Fav Mod:
Ok,thanks for the reply. Ive looked for that video with no luck. is it under the installation or exterior forum??
Old 07-30-2007, 07:01 PM   #5
Car: 06 STI SGM
Fav Mod: seatbelts
Send a message via MSN to boost_happy
Here's the link to the first video and the second video is below on the link. This is what I used and its great. Oh and your welcome. You'll love the flappers, I know I do.
http://www.hspn.tv/?videoid=42
boost_happy is offline   Reply With Quote
Old 07-31-2007, 05:21 AM   #6
Authorized Manufacturer
Car: 99 Impreza WRX
In addition to the video above here is a printable link to the instructions for your vehicle:
http://www.rallyarmor.com/store/wrx_...ons/index.html
Thanks much
R/A
Rallyarmor is offline   Reply With Quote
Old 07-31-2007, 07:17 AM   #7
Fav Mod: TiC AST Coilovers!!!
Trader Rating: (86)
I got used RA's and installed them with some screws & plastic concrete fastener pronged things, they work well
WC LATHE WERKS is offline   Reply With Quote
Old 07-31-2007, 07:29 AM   #8
Fav Mod:
sweet!!!Thanks....i printed out the ra version and im sure it is going to help big time. thanks for the feedback. im going to install them now!!!
Old 07-31-2007, 07:33 AM   #9
Car: Aspen White 05 STI
Fav Mod: HKS Carbon Ti
I had the same problem with mine on my 05 STI...finally got them to work but it took longer than expected.
FRESH2DEF is offline   Reply With Quote
Old 07-31-2007, 07:45 AM   #10
Car: 99 Impreza WRX
Excellent-
to note, in some instances you may have to realign the clips in the front sections slightly after placing the liner because of the close proximity of all the pieces. A pick, small screwdriver can come in handy for this. Aligning it until you can see the clip behind the liner as shown in the left side of the picture.
Another tip is to confirm that the insert (shown circled above) is completely flush in order for it to properly expand
Thanks again
R/A
Old 08-14-2007, 02:31 PM   #11
Car: 06 Subaru WRX STI
Fav Mod: Headlight Adjustment
Send a message via ICQ to MasterColin Send a message via AIM to MasterColin
I installed mine using the video yesterday and it worked great. These things Rock.
MasterColin is offline   Reply With Quote
Old 08-29-2007, 09:24 PM   #12
Car: 06 Mitsu Evo IX SE
Fav Mod: Muellerized Stage 2--JICs
Send a message via AIM to BLACKOUT Send a message via Yahoo to BLACKOUT
Don't forget to drill your mounting holes .5" to 1" higher than stock, depending on how low you're dropped (if you're dropped). If you don't drill the holes higher, and you're dropped, you will scrape the sh!t out of your flaps, and possible tear them out of your fender lining.
J
BLACKOUT is offline   Reply With Quote
Old 08-30-2007, 04:14 AM   #13
Car: 99 Impreza WRX
Blackout, there is no need for height adjustment on the URs, they flex to accomodate lowered vehicles and are specifically made to accomodate this as well.
Old 08-30-2007, 07:32 PM   #14
Car: 99 Impreza WRX
One additional note. Our V4 Classic series mud flaps are higher up about an inch than previous models as per this announcement:
Rallyarmor Rally Mud Flaps V4 02-07 WRX/STI
Old 08-30-2007, 09:45 PM   #15
To quote Uncle Borat--"Very NIZE." I don't know which version of your flaps I have, but regardless of whether or not I had to drill the holes up higher, RA flaps ROCK!!!!!!!!!!!
+1,
J
