Old 07-30-2007, 06:03 AM   #1
Default PCV Valve Hose Clamps Need Help
In this pic is the white thing the pcv valve? If so, how hard is it to get to and change on an 05?
BBKG79 is offline   Reply With Quote
Old 07-30-2007, 07:31 AM   #2
Fav Mod: EQ Tuning
Default Re: PCV Valve
no the pcv valve is the lower black plastic piece that the sensor is connected to. the piece you're referring to the the blow-by sensor.
BM_STi is online now   Reply With Quote
Old 01-23-2008, 11:46 AM   #3
Ok I finally got around to doing my PCV valve today, removing the clamps was easy. How in the world are you supposed to reclamp the hose clamps?
There's absolutely no room at all, they're stiff as hell. I used a needle nose to remove and I'm trying to use them again to close but they keep slipping. I went and bought some regular hose clamps that require the use of a screwdriver/ratchet/wrench and there's not enough room to do any of that or long enough to reach.
I'm at the point where I'm ready to leave that thing unclamped
Any recommendations???????????///
Old 07-07-2008, 01:14 PM   #4
Fav Mod: Tank the Terrier!
Send a message via MSN to RAPTR
Default Re: PCV Valve Hose Clamps Need Help
Zip ties? I hate that the reccomended maintance calls for replacement of these things.
RAPTR is offline   Reply With Quote
Old 07-07-2008, 02:12 PM   #5
If in doubt, flat out
Trader Rating: (23)
You need hose clamp pliers. They're available at any autoparts store for a couple bucks.
Old 07-24-2008, 03:31 PM   #6
Car: Blue 04 Subaru WRX
Fav Mod: I love my TBE because the sound of the STi engine is like nothing I have ever heard.
Send a message via AIM to ur2s2pid
I switched my clamps to a regulaur screw type clamp and used a wrench and about half an afternoon tightening
ur2s2pid is offline   Reply With Quote
Old 07-29-2008, 03:20 PM   #7
Car: 04 Sti Wrb on Silver
Don't know if it is good for the engine at all but, I deleted this. Blow by sensor is sealed with stuff and the Pcv hose goes to the catch can and then free air. No problems so far and intake track is shinny clean.
