Old 07-17-2007, 10:10 PM   #1
Car: 07 FXT
Default Maddad TBE Install
Finally, after two years of ownership I've taken the plunge and purchased the first major mod, I am mechanically inclided with no experience installing a TBE.
I want to do it right the first time.
What is the most accurate and complete thread on installing a TBE "On an STI" not WRX, not FXT, STI, STI.
Hopefully with pics too.
Thx.
gSTrIng is offline   Reply With Quote
Old 07-17-2007, 10:39 PM   #2
Car: '05 WRB STi
Fav Mod: Open Downpipe
Default Re: Maddad TBE Install
Hmm, I'm surprised the DP install portion isn't in the how-to catalog. Anyways, heres a walkthrough for the downpipe install http://www.scoobymods.com/forums/sho...xhaust+install
TBE installs are extremly easy if done right, use a good amount of penetrating oil on the 5 nuts and 2 bolts on the turbo. As for the cat-back portion... Once you get under the car you'll see how easy it is, 4 nuts and bolts with 3 exhaust hangers, probably the easiest DIY mod on the car. Good luck with the install oh yeah, its also easier with a lift if you have access to one, takes like 2 minutes to take off the CBE
btw: heres a how-to for the CBE portion http://www.velozt.com/html/exhaust_index_in.html
Evan is offline   Reply With Quote
Old 07-18-2007, 08:22 AM   #3
Car: 07 FXT
^^^^^^^ Thanks hopefully I can do it solo, I don't like help when it comes to work on my car, I like to take my time and just bugs me when I am being rushed.
Old 07-18-2007, 08:52 AM   #4
Car: Silver 05 WRX STi
Fav Mod: Advan RGIIs
You may need to port your wastegate as well in order to avoid boost creep. I would suggest a boost gauge if you don't already have one FWIW
mdefalco25 is offline   Reply With Quote
Old 07-18-2007, 10:19 AM   #5
Did you purchase your TBE recently and receive it from Maddad ? Just wondering because im going to order too and wondered how long it take to receive .Also install is easy.
martyq is offline   Reply With Quote
Old 07-19-2007, 08:17 AM   #6
Car: Family, Car.
Fav Mod: Anything MadDad
We've going to have a bit of backlog on Whisper CBs because our supplier of the tips is no longer has the style we were using. We're in the process now of sourcing tips for the exhausts. Other than the last couple of orders we got this week it's going to be a number of weeks before we see Whisper CBs back in. V2 downpipes will be shipping again in about 2.5 weeks, we have the two-piece version in stock. The new MadDad catted bellmouth will be available in about 2 weeks to ship. Catless versions are now in stock.
R.
daddysscp is offline   Reply With Quote
